Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Sony plasma colour problem
Hi i have a sony plasma pfm42v1,after watching it for about 30 - 35mins.the light colours like white starts to flicker orange(like pulsing)orange and it gets worse as time goes by,can this be solved
  • gmannct Apr 24, 2008
    i have the same problem with mine
HOW MANY PROCESSOR BOARDS ARE IN THE SET I CHANGED TWO ALREADY THE PROBLEM STIL EXITS,ANY OTHER SUGGESTION OTHER THE SONY WHERE THIS BOARD CAN BE HAD?
Posted on Aug 20, 2008
    Genius:
  • Panasonic Master
  • 1,673 Answers
There are some parts on one of the processor boards that have become thermo sensitive with age and use.
An experienced service tech should be able to find the thermo sensitive part by using the technic of cooling the suspect areas with liquid air and heating them back up with a heat gun to provoke the fault. With this type of process it should be possible to zero in on the parts without going in to very complicated analysis.
If the parts become permanently failed, then the only way to fix the set would be by board swapping, as how these sets are normaly serviced.
If the failed parts are proprietary type parts that cannot be genericaly bought, then they will have to be ordered from Sony only. Normaly, Sony only sells the complete boards for these TV sets. They do not fully support component level service for many reasons.
Considering the age of your set, it is very possible that parts for your set will no longer be available from Sony. I found that after about 3 to 5 years, most of the parts were no longer available for most of these models of sets.
Jerry G.
Posted on Apr 30, 2008
My Plasma 42PD580DTA
I assume your DVD is coming up in colour when you plug it into a standard scart connector? Have you tried using a different S-Video cable because this sound symptomatic of a dodgy lead?
Check the SCART end of your lead for any bent or broken pins.
Failing that if the problem lies with the TV itself I'd really recommend having a pro look at it. Plasma's are expensive and opening it up if you don't know what you are doing is a bad idea.
Dec 02, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Plasma Problem
It could be the Logic board or/and one of the Logic Scan board failure. Parts availability depends on maker and may cost any where between $250 - $500. Labour depends on shop. Hope that'll help you. Good luck.
Jan 26, 2008 | Televison & Video
Colour problem with my Sony KV-X2931S 29
Hi.
This problem is usually do a 15pf varicap faulty.
Not expensive to have repaired.
http://dysonmanuals.llc.nu/
Chris.
Dec 30, 2007 | Televison & Video
Lg mz42pz44 plasma tv
Have a look at my 'I broke the glass post'
Dec 02, 2007 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
Sep 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
PANASONIC TV, TH-42PX60
If it's just one video plug, then perhaps you have to set av5 as being in colour somwhere in the menus.  If you require three wires for the pictures, as blue, green, and red, then make sure they aren't in the wrong ports.
Good luck.
Jan 16, 2007 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
88 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
