Question about Canon PIXMA iP4000 InkJet Photo Printer
Suddenly stopped printing all colors. Will only
Pixma ip4000 was working great. Suddenly stopped printing all colors. Will only print the 3e black check pattern. Will not print any of the color check patters. Deep cleaning doesn't help anything. Black printing is great!
  • 1,219 Answers
Hi, it could be few things wich you having problem with.
First, how old are the ink tanks, it could be clodged.
Second the print head nozzles are clodged at that places.
Third, the purge unit does not work OK.
First remove all inks out and remove print head. Then on wet cloth, wet it with distiled water, few times press the bottom of print head ( nozzles ), then the 4 circles must change from colour to white. That means that nozzles are cleaned.
Dry head by pressing it on dry cloth.
Put it in, also the inks, and run few times the deep head cleaning. Every time take a look at print pattern.
If the head is to badlly clodged, test pattern would be just a little bit more better.
But now you know if the problem is in head or something else ( purge unit or inks ). The new head isnt so cheap regarding the printer so then the best solution would be to buy new printer.
If you do not want to buy laser colour printer, atleast buy one on wich ink tanks has printhead on. Its slightly costly, but you have one worry less - the print head is changed every time you change the ink.
Hope that helped
Posted on Jul 18, 2010
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Cartidge 3E Black not printing
make sure the smaill tape on the ink cartridge is peeled off.
Jul 25, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Only black ink won't print. Even with new black 3e and new black 6 cartridges.
The black ink is a pigment based ink, that is it consists of particles suspended in a solution. The colors are dye based and have no particles. This being the case when the black ink dries and clogs the print head the particles are left behind. I would suggest removing the print head and letting it sit on a paper towel moistened with warm distilled water. Do this on a surface that is both waterproof and disposable, i.e. a plastic disposable plate, since the hope is that ink will flow out. Let this sit for about 20 mins, reinstall print head, making sure the electrical contacts and clean and dry, then the cartridges and try cleaning cycles again. If still no luck replacement print heads are available at the address below.
http://www.precisionroller.com/print-heads-for-canon-pixma-ip4000/products.html
Jun 11, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
IP4000 - How can I force the printer to use the large black (6) ink cartridge?
Do you mean the large black ink as in the 3e vs. the 6? If so, the large black, 3e, is a pigment based ink and the printer should only use it when print text and black and white things. The 6 black is a dye based ink and the printer should only use it when printing photos.
Jan 14, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Ip4000 printer prints but with horizontal lines
Cannon recommend a cleaning process called deep head cleaning
  1. Open the Printers folder.
    - For Windows XP select 'Start', 'Control Panel', 'Printers and Other Hardware', and 'Printers and Faxes'.
    - For Windows versions other than Windows XP select 'Start', 'Settings', and 'Printers'.
  2. Right-click the printer icon and select 'Properties'.
  3. Click the Maintenance tab, and then click the 'Deep Cleaning' icon.
  4. Select the ink tank color(s) for deep cleaning ('All Colors', 'Black', or 'Color').
  5. Confirm the message, and then click the 'Execute' button.
  6. The Power lamp will blink and print head deep cleaning will start. Deep cleaning completes when the Power lamp stops blinking and lights. (It will take about a minute for the Power lamp to stop blinking and light solid.)
  7. Print a Nozzle Check Pattern by holding down the <Resume> on the printer until the Power light flashes twice to determine if further cleaning is necessary. Up to three deep cleanings may be necessary to determine if the print head is working properly
Sep 11, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Cannon pixma 1500 printer stopped printing color ink is full
Print a test pattern print first to make sure that the problems is the printer and not the file you are trying to print , then check you color cartridge if it's empty.
Aug 17, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
847 people viewed this question
old marine
old marine
