Question about Maytag Neptune FAV6800AW Top Load Washer
Didn't rinse properly, the'res more soap left on clothes as well as clothes small parts are still left on clothes after rinsing
  • Maytag Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinedidn't rinse properly, the'res more soap left on - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jul 17, 2010
How do I clean the washer to eliminate the dark spots of lint and dirt on laundry?
Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle.
To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again. Add 1 cup white distilled vinegar to a large pot of water, bring it to a rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing, as well as those left by deodorants, by spraying full-strength white distilled vinegar on underarm and collar areas before tossing them into the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy? Pour a few cups of white distilled vinegar in the machine and wash the clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes by filling the bathtub with very hot water and 1 cup white distilled vinegar. Hang the garments above the steaming water and shut the door so the steam can penetrate the fibers.Keep the steam iron clean and in good working order by getting rid of mineral deposits in steam vents and spray nozzles. Fill the water chamber with a solution of equal parts white distilled vinegar and distilled water. Set it in an upright position and let it steam for about 5 minutes. When the iron is cool, rinse the tank with water, refill and shake water through the vents onto an old cloth. Test before using.Remove scorch marks from an iron by rubbing it with a warmed-up solution of equal parts white distilled vinegar and salt. If that doesn't work, use a cloth dampened with full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry! Add about 1/4 cup white distilled vinegar to the last rinse. The acid in white distilled vinegar is too mild to harm fabrics, yet strong enough to dissolve the alkalies in soaps and detergents. Besides removing soap, white distilled vinegar prevents yellowing, acts as a fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine with white distilled vinegar. Periodically run the machine with only a cup of white distilled vinegar in it-nothing else added to the wash cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water.
Get rid of the tiny holes left along the hemline when you take out the hem of any garment by moistening a cloth with white distilled vinegar, placing it under the fabric and ironing.
Oct 31, 2011 | Whirlpool Washing Machines
Soap
How much HE detergent is used can vary from household to household, depending on such factors as water softness level, soil level of clothing, load size, etc. Because excessive suds can cause build up in the machine, leading to decreased cleaning performance, odor and damage to parts, reduce the amount of detergent if sudsing occurs. How do you know when you have gotten all the soap out? Try extra rinse and make use of custom program to perform additional rinse.
Sep 09, 2007 | LG WM-2277HW Front Load Washer
When washing dark colors there is a soap residue left on clothes,i have tried using very small amounts of soap as well as different brands of soap
Try using white vinegar in place of liquid fabric softener. Half a cup at the rinse cycle in a full load will do it. Trust me, the smell of the vinegar will fade quickly as it works to break down the soap.
There are two other possibilities here:
You're overloading the washer with clothes - An overfull washer has the problem of not providing proper drainage before the spin cycle starts - Soap ends up getting embedded in clothes instead of being sucked out of the drain.
Or, You're using non-HE soap in an HE washer.
Hope that helps.
May 04, 2011 | Washing Machines
Washer doesn't rinse well. Doesn't spin water out properly.
Ok.you need tro make sure that its pumping out okay...if not check the filter..then pump..
Feb 21, 2010 | Washing Machines
Does it matter what kind of cleaner I use on the Deep Cleaner Model F5821
Yes it does matter which cleaning solution that you use in your steam cleaner. If you use the wrong cleaning solution it may cause problems with the cleaning solution dispensary system. Different steam cleaners use different cleaning solutions. You should always use the steam cleaner solution for your specific cleaner. I have learned this the hard (and expensive) way.
Hard to recommend this but it will work in a pinch. You can use a small amount of liquid laundry detergent diluted with hot water (about 2 table spoons to a gallon) as a stand in for the real deal. DO NOT put the laundry soap solution into the cleaning solution reservoir (the wax content will clog the soap dispensary system). Lightly apply to the area to be shampooed (do not soak). I have used a plastic coffee can with holes poked in the lid like a watering can to apply the soap solution. Use the shampooer to do the scrubbing and remove soapy water from the shampooed area. Fill your soap reservoir with clean hot water. The laundry soap does most of its job during the rinse. Go over the shampooed area with the shampooer moderately soaking the shampooed area to with the hot rinse water. Remove as much of the rinse water as possible. Liquid laundry soap has a high wax content (makes your cloths soft) and if it is not rinsed thoroughly after it is dry the remaining wax will attract dirt faster than the surrounding areas. Other than that it works for a good stand in for the proper detergent in a pinch. As a bonus it smells great.
From what I understand as unorthodox as it is, it works well in small doses, and I don't believe that it causes any damage to the other parts of the steam cleaner as steam cleaners survive drawing up worse things into them than laundry soap.
I hope that you find this helpful
Good Luck!
Jul 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Dark dirty spots on some clothing items appears on every load.
what you are seeing is suds getting back onto the clothes. make sure you are using HE type soap and not using too much of it.
if you are seeing suds inside the unit, when it is running, then it will "re-deposite" dirty soap residues back onto the clothes.
you need to run a rinse and spin cycle or even a heavy duty cycle with hot water to rinse out any soap that is left in the unit.
not a major problem, just use it differently and it will be ok.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Whirlpool Quiet Partnet II Rinsing solution compartment
WITH REGARDS TO YOUR MACHINE NOT TAKING THE FULL BOTTLE OF RINSE AID YOU WILL HAVE TO TRY AND CLEAN OUT THE SOAP POWDER THAT WAS PUT IN THERE YOU MIGHT NEED TO STRIP THE DISPENSER DOWN IF YOU CAN NOT CLEAN IT FROM THE TOP.
IF ALL FAILS IT WILL BE BNEST TO CHANGE THE DISPENSER :-(
GOODLUCK.
MOHAMED
Jun 01, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
My Maytag front loading washer does not fully rinse cloths MAH8700A. I purchased this washer about 6 months ago. I usually wash small loads but have noticed it doesnt matter what size load. When first...
Is the drain path free-flowing? That is, does the water eject freely during spin/rinse? Maybe there's a restriction in the line, or it's too high above the washer.
Feb 25, 2007 | Maytag MAH8700A Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
81 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
