Question about Little Giant 5-MSP Water Wizard Submersible Pump, 1200 GPH
How do you replace a broken power cord - Little Giant 5-MSP Water Wizard Submersible Pump, 1200 GPH
  • 2,760 Answers
Due to the seals involved and the increadable possibility of leaks happening i dont recomend that you try replacing a power cord on a submurged pump, the risk of shock is just to great for the benefit !! the plug end now that can be replaceed however , contact any licened electrician they can handle that for you.
Posted on Jan 31, 2015
Power cord is broken on my bose 321
Is the power cord bad, or the jack in the unit that you plug the AC cord into broken? If you're interested in repairing your Bose, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Dec 22, 2014 | Bose 321 GS series II
Power intermittent: when cable is touched power returns
You have a broken power cord. Hoover is notorious for power cords. I'm speaking from personal experience. Replace/have the power cord replaced.
May 08, 2012 | Vacuums
What cause a skil HD 7702 Type 15 to overheat?
Overheating can be caused by:
- running the saw on a long, low-guage extension cord or with a damaged power cord. Eliminate extension cords or replace with heavier cords, at least 12 guage or better. Replace power cord if damaged.
- too much "stuff" packed in and around the armature and field so air cannot curculate and cool the tool. Blow out the body.
- broken, worn or seized armature bearings. Check/replace if needed.
- broken, worn or seized transmission and blade arbor bearings, usually caused by low or no oil in trans case, check and replace as needed.
Apr 05, 2012 | Skil Saws
My bosch maxx laundry machine wont turn on
If you dont have power to the machine, your electric cord from machine to power point is broken. To check this turn on at power point and at machine hold cord in hand and shake if machine makes any noise you have a broken lead which can be cut at break and fixed,but better replacing with new cord Hope this helps
May 25, 2010 | Washing Machines
No power- no lights
hi
check to see if the cord is well connected nd also check to see if the cord isn't broken,also check if the pin isn't broken too. test it with another lexmark cord to see if it works,if it doesn't then the power pack is faulty and you should have it replaced
goodluck
Feb 18, 2010 | Lexmark E234 Laser Printer
My power cord has broken at the tip. Can I
Braun Syncro 7570 power cord is Braun 7030458 adapter charger cord.
Feb 08, 2010 | Braun Syncro 7570 Electric Shaver
The Charging cord's head that fits into the Shaver is broken. How get I get a replacement?
I have several new power charging cords for this model. If you want one Please let me know and will give you a good price.
Nov 13, 2009 | Braun 8585 Electric Shaver
HP Compaq nx7300. Pin has broken off from the power cord supply. Mains input cord now won't work as part of pin is possibly stuck inside. Took to original supplier who quoted £220 to replace entire...
absoloutly not!!!!! if the pin has broken in the external power cord and not inside the PC itself then all you have to do is replace the PSU ( power supply unit ) and the lead, this should cost you no more than £35 and its easy to replace yourself
Nov 18, 2008 | HP Computers & Internet
Little Giant 5-MSP Water Wizard Submersible Pump, 1200 GPH Logo
174 people viewed this question
Top Little Giant Garden Experts
J.D. Browning
J.D. Browning
Jim Goldsmith
Jim Goldsmith
Mike Squire
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
