Question about Boating
Control cables when taken to fast forward the motor slows when put in reverse the motor screams. the cables seem to be hooked up ok could there be another problem. the motor is a 40 hsp 2 stroke,2cyl,79/80 mercury outboard.
    Guru:
  • 642 Answers
Cables seem to need adjustment. Or perhaps you switched them around. Put the control in neutral. No throttle. Disconnect both cables from the engine.In neutral the shift cable should be half way out. You can determine this by moving the control to forward then reverse to make sure(shift cable will retract and protrude fully when shifting). Reconnect shift cable to the motor when the motor is in neutral(prop spins free) Once connected put the throttle cable back. The throttle cable should be adjusted so that when in neutral and no throttle opening the butterfly valve on the carb should be fully closed.
Posted on Jul 17, 2010
Jazzy goes fast in forward slow in reverse
It is supposed to. Forward you can see where you are going and normal steering applies. In reverse, you can't really see where you are going and it is only for backing up. Also reverse steering applies, so you turn left to go right, which is confusing for old folks, especially at speed. In Forward, the throttle should be responsive, slow to fast.
Feb 03, 2017 | Health & Beauty
My golden companion 2 Gc 321 goes forward when i push reverse and goes reverse when i push forward
Sounds like the motor cables are in reverse at the controller. Check that the red is in the positive and the black wire is in the negative on the controller.
Aug 12, 2014 | Golden Technologies Golden Companion 2 -...
Buick lesabre loud noise when braking
Are the shoes adjusted up close to the drums?
Aug 15, 2017 | 1997 Buick LeSabre
Runs very slow speed forward or reverse. full chg battery
you may need to fit a new battery or the drive motor has burnt out?
if the battery is over 3 years old its past its sell by date and if its been ran fully flat often or left flat that will shorten its life as well,,,
the battery is not to pricy,, you could try testing the motor by hooking up with "jump leads" a car battery just to check the motor is ok,,,
Jul 31, 2010 | Peg Perego John Deere Gator HPX
I have a 95 model 25hp mariner when selecting neutral i can only do so by going to reverse first. Going from forward to neutral it still stays in forward gear.
hi disconnect the remote gear cable on the motor then try it if you can get all gears and neutral without going into reverse all is ok put the cable back and ajust it if it won't work the control box is worn hope this helps merlin v12
Aug 26, 2009 | Boating
Mercury 115 problems
This could me that reverse gear is not fully engaged.Adjustment on the cables is needed.Take the cowlings off.With the motor not running,move the throttle/gear selector into forward and reverse.You will see where the cables move in the engine area.Note which way the cable moves the selector when reverse is selected.Do this next bit from inside the boat.Hook up the flusher to the motor and start it.Select reverse.When you hear the grinding,push the selector by hand in the direction of travel.It should engage the gear fully.You will see the adjustment threads on the control cables.Move to suit.Hope this helps
Jul 28, 2009 | Boating
Platter spins very slowly
Well hope fully its something small. check your pitch control first make sure its not set at a slow speed. then check your start stop knobs at the bottom of the table. roll them one way then start it see if that works, then the other way... if its not that then its possibly its a malfunction ,, Numark with there new awesome products but sometimes faulty that turntable wigs out goin slow then normal then slow ect... If its less then a year send it in it is coverd by warrantee
Oct 07, 2007 | Numark CDX Turntable
Boating Logo
66 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
