Question about Gateway FPD1975W 19" LCD Monitor
GATEWAY MONITOR The left one third of my monitor is blank,everything is pushed to the right. how can i correct this?
  • 105 Answers
Are you using video resolution 1440 X 900?
Have you tried "auto adjust"?
Monitor Mike
Posted on Jul 19, 2010
4 - 4 - 4 - 4 =20 put mathematic signs (+,-,*,/) in the blanks and try to find a correct way.
This is the classic "Four Fours" problem. Combine the four fours as
4 / 4 + 4 * 4 with the operations taking place from left to right. The first 4 divided by the second produces 1. Add the third 4 to produce 5. Multiply by the fourth 4 results in 20.
Feb 06, 2013 | Computers & Internet
I just installed win7 and all mi icons are big, everything is big, please help me.
Right click on the desktop and go to personalize. Down in the bottom left corner click Display. Choose smaller 100%. If this is already checked, Right click on the desktop and click screen resolution. Pick a higher resolution and click apply. The higher the number the smaller everything will get, For Example. 1280x 720 is much smaller than 800 x 600
Mar 12, 2011 | AOC LM560 15" LCD Monitor
Can't adjust contrast
restore your factory settings and then try
Oct 16, 2010 | Samsung SyncMaster 2253LW Monitor
My display resolutin is too small, thatswy my screen shows very small as compared to monitor size....!! what can i do? the H size and V size is correct..!!
You probably know about adjusting the monitor display size by right clicking on a blank area of the desktop, choosing properties, settings and moving the slider towards the left. 800x600 will make everything very large. (XP instructions)
You can also get there via the control panel, display, settings.
While on that page, you can click appearance and change icon size.
Aug 22, 2010 | Computers & Internet
System starts up but goes to blank screen
This may happen due to several reasons. First, check if the power supply line to the monitor is loose at any of the two ends. If yes, tighten it. As a simple measure, keep that blank screen and tighten the codes to see if it works. If that is not the case, switch off your system and UNPLUG it. Then open up your CPU and clean all those dusts present there. Sometimes this problem can occur due to moisture present there. So wipe everything with dry cloth. CAUTION: DO NOT USE COTTON. USE ONLY A DRY CLOTH. Before closing down the CPU, take out the RAM(s), wipe it's tip with CLEAN COTTON slightly dipped in spirit (After Shave Lotion will do). Then put back the RAM(s) in position. This is not only to clean it, but also to make it a bit more seated. Now start up your system to check if it is OK. If none of this works, try re-installing the OS. This is a last measure and it can fix your problem, mostly.
Jul 06, 2010 | E-Machines eMachines Desktop PC
Lost manual to Bell wireless bicycle computer
Here are some things the book doesn't tell you:
You have to completely reset the speedometer and lose your odometer to reset the MPH. Hold both buttons for 3 secs to get reset. (Remember to use the left button to walk through the setup process and use the right button to change the settings.) First set the wheel size using Ideluna's settings above on this page (right button to change the setting and left button to go to next number). Next is MPH/KPH, after wheel size setting, push left button again and km flashes. Push right button to change the setting to MI. Next is TIME. Push left button and you'll see the time. Hold down left button till 24hr appears. Push right button to change to 12hr. Then push left button to go to flashing hour. Change with right button. Then left button to go to flashing minute. Right button to change minute, hold down to change minutes fast. Now you are set up. Now the process changes, use the right button to walk through the menu and use the left button to reset. Don't push both buttons anymore unless you want to reset everything again. If you want to reset something just hold the left button down until 0. When you are in SCAN mode, push the right button to go to Time, To go back to SCAN once, hold the right button down - It will scan everything once and return to TIME. To go to ODO, push right button once, push again for DST, push again for MXS, push again for AVS, push again for TM, push again for SCAN to stay in SCAN.
Mar 24, 2009 | Cycling
Monitor is blank/dimension 2400
If you put a spare monitor on your computer and everything is fine I'd say it has an electronic problem. If the screen is still blank I would look at the video card or PC itself as the problem. Just for fun check the video cable for bent or missing pins.
Mar 23, 2009 | Computers & Internet
LCD blank screen, blink white
blank_page Use a reset sequence on the monitor-
1. turn off monitor
2. unplug power
3. plug power back in, holding down the last button on the left, then push the power button to turn back on and off three times, holding on the third try until it comes on- hold for ten seconds and release; the monitor should work again
Jul 28, 2008 | Computers & Internet
Acer Aspire 5100 will not start right
It seems your hard drive has corupted.
This sucks, all you have to do is push ALT F10 and then go through the reseting menu, you will loose everything on there though except the original data.
Jun 24, 2008 | Acer Aspire 5100-5033 Notebook
Pushed wrong button
You got a clue by now and pushed that button 2 more times, right? And the Rapture happened and it went back to right? Yep. No problem. Keep that PDF manual for the monitor around for light reading, too.
It seems like the right button to push to me, too. Maybe if I had CCTV on the doorbell or backyard or something it would be; otherwise it is the one third from the left.
Feb 20, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
37 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
