Question about Kohler Model 10430: Fort® Single-control Remote Valve Kitchen Sink Fauc...
I've taken the spout off and can see the diverter but I can't get it out of there. How do you get it out?
I have a K-R10430. I was having issues with the hand spray - poor water pressure. Kholer sent out a new diverter. After shutting off watner, when you remove the small screw in the back of the Spout, pull the spout off. Put a paper towel into the body to soak up excess water inside body. Then you need a small screw driver or small flat item to fit inside one side of the retaining ring near the opening, there is a space where you can fit something behind and carefully move the retaining ring out. Pull out with needle nose pliers then pull the diverter out with needle nose pliers. Insert new diverter with teeth facing up and push down. Insert retaining ring and make sure it slips into same **** in wall of body.
Posted on Jul 25, 2010
  • neilrathjen Jan 09, 2011
    Locate a large diameter wood screw that can be screwed into the hole in the middle of the old diverter and pull the old diverter out. I had the same issue and this worked fast and efficiently. If the top part of the old diverter (White in color) is still in tact, pull it off with needle nose pliers exposing a hole now use the wood screw.
2 Suggested Answers
  • 297 Answers
SOURCE: Tub shower diverter stem on tub spout broke and
you must replace the whole stem.you can get it at homedepot. first take the cover off over the stem. this should screw off or is held on with a allen key.then unscrew stem from valve body.make sure water is off to tub,just in case.
Posted on Jul 15, 2009
Can I clean tub spout diverter, does it unscrew so I can clean aerator?
Even if you unscrew your diverter, there isn't anything you can do to make it perform any better. It's best to replace your tub spout/diverter combo. I imagine your getting water out of the spout when in shower mode......they do wear out when used a lot. If you decide to change your spout, write back and I can guide you through the process of ID and removal/replacement procedure. But if your not a pretty good handy person, call your plumber to do it 4 u. He would appreciate your business. Good luck with your problem and always know where and how to turn your house water supply off before attempting a plumbing repair. :-)
Jan 28, 2013 | Delta Faucet Delta RP17453 Pull-Down...
Shower head wont turn all the way off
the seal on the diverter may have fallen off, or bad/dirty diverter.
when the water is turned off, does the diverter return to "normally open" state? (no divert, goes directly through tub spout)
Apr 16, 2012 | Home
I have a garden tub w/o a shower attached. However, the fixture in the tub is the Delta pull down diverter (dont know why they would put that in a tub w/o a shower). Anyway, the diverter was pulled down...
If it was me... I would replace that spout...
the spout either is threaded on or it has a set screw on the bottom at the back that you loosen and then pull the spout off by pulling straight away from the wall...
Check and see if the spout has the hole for the set screw...if not then twist it counter clockwise and it will turn off...
then repalce the spout with a new one with out the diverter...
heatman101
Aug 05, 2010 | Delta Faucet Delta RP17453 Pull-Down...
When I run water through this tub spout (diverter in down position) I still have water leaking from the showerhead. I have seen water from a tub spout when the shower is on, but not the other way around....
After you turn water off in about 30 secs pull the diverter up and leave for a few minutes This should allow the water left in shower piipe to drain out the spigot
Feb 17, 2010 | Speakman S-1555 Versatile Bath...
There is a very slow leak only at the weep hole site under the faucet, not at the main faucet outlet
The hole is designed to let water out instead of going back into your wall. The spout needs to be taken off (unscrewed usually by hand) and tephlon tape needs to be put on the threads coming out of the wall. After this is done, screw the spout back on. Should be all set.
Dec 31, 2009 | Delta RP17453SS Standard Diverter Tub...
What happens when you pull down the diverter on a tub only, where does the water go? and how do you fix it?
The water stops at the spout .You can replace your tub spout with one that dosnt have a diverter. It isnt neccisary though ,the one you have is fine,jest dont pull down on the diverter.
Dec 02, 2009 | Delta RP17453SS Standard Diverter Tub...
My delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
Sep 28, 2009 | Delta Faucet Delta RP17453 Pull-Down...
Shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Jan 30, 2009 | Price Pfister 01-311 Shower Head, Tub...
Kohler Model 10430: Fort® Single-control Remote Valve Kitchen Sink Fauc... Logo
765 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
