Question about Dometic Rooftop RV Air Conditioner
Duo Therm Model 59116.502 only runs when bypassing control board
I have a Duo Therm Model 59116.502 [about 1995] and the compressor seems to stall when when thermostat is turned on. Fan runs fine. Bypassing the control brd and applying power direct to compressor the unit runs fine. Is this an indication that I need a new control brd or would you recommend a new unit in light of its' age?
22yooper
  • 828 Answers
SOURCE: duo-therm by dometic ac rv unit
I suspect that you have a bad selector switch for the on, off, low fan, high fan operation. If the selector switch is put into the off position everything should stop completely.
Posted on May 31, 2008
SOURCE: duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Posted on Jul 19, 2008
jmeredith
  • 417 Answers
SOURCE: compressor tries to start but want
hi,
you have to run a contractor grade extension cord(10-12 gauge) from your rv to run those or theyll do that, the lower the gauge the better, best bet is to plug the rv directly into the outlet, if you cant, get the shortest and thickest extension cord you can.
Posted on Aug 21, 2008
  • 659 Answers
SOURCE: Duo Therm compressor tries to start and kicks out
I don't think these little units have a start capacitor but what I would do is check that the on/off switch wires to make sure they aren't loose. Also check the wires to the compressor for loose wires as well. It is possible that these are the first signs that the compressor is about to fail. They also can act up some when they haven't been used for awhile and then you try and start them up. Try running the unit for a few hours without asking it to cycle. It might just be a sticky valve.
Posted on Apr 13, 2009
  • 67 Answers
unfortunatly with the new laws u are unable to unless u are a licenced refrigeration/ac technician
Posted on Sep 16, 2009
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
Sep 08, 2013 | Dometic 3312024.015 Duo Therm Comfort...
Duo therm air conditioner that the compressor will not start
Hello,The freezestat should be closed.Try jumping that out .
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
Duo-Therm model #57915.531,compressor keeps running after condensor fan shuts off.Relay? circuit board?
yes i would say it is a relay or it been wired incorrectly. you can check it manually by pushing it down and see what happens unless there are two relays.
Jul 14, 2009 | Heating & Cooling
Penguin AC cycling
Did you try contacting Dometic directly, to speak to a technical assistant. ( www.dometicusa.com )
Jul 09, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
138 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
