Question about Casio G'zOne Boulder Cell Phone
My Casio Boulder won't turn on. It has no power,
My Casio G'z One Boulder won't turn on. It has no power, will not charge even with a different battery. I had a cell phone certified tech take it apart and he is baffled. No one has a solution.
5 Suggested Answers
  • 137 Answers
SOURCE: ringtones
you have to format the memory card first to the phone.. easiest way to do this is to take a picture from the phone and transfter it to the card...
at this point the card will now have folders associated with the phone on it..
if you put your sd card into your computer and see any files that are not in a "my_pix, my_flix, my_ringtones etc" folder, drag them to the appropriate folder and you will be able to access them through the phone
so if you wanted to do ringtones drag the music into the ringtones folder. if you wanted music drag it to the music folder
Posted on Nov 10, 2009
firesnake09
  • 2923 Answers
SOURCE: will not charge
It could be that the battery is bad. Bring your phone in to any repair shop and try using another battery. Most cellphone shops or stores has a test battery.
If you couldn't find a test battery, refer to a cellphone tech to test if the battery is still okay.
Posted on Jul 28, 2009
kachi_1
  • 677 Answers
SOURCE: my casio boulder will not charge how do I fix it
Hi, you can check with another charger first to know exactly what the problem really is before you can take the next step .Also check the phone on another charger.
After checking with another charger, if charger work,that means the charging sport where you plug in the charger is not working and need to be replaced.
If when you check the charger with another phone and and the charger doesn't work, replace charger.
Take care.
Posted on Jun 15, 2010
SOURCE: my casio gz boulder phone
Hi, it's a common known problem that this phone's internal charging system FAILS after about 4-12 months...I have to literally tie a rubber band to the charger's "line" while the phone is being charged to get it to work. (You know--when the red light comes on it's charging--so you have to get the charger line in a certain place & keep it there so it will work.) A real pain in the ***--I'm 17 days from an upgrade--which sux, because I like this phone other than this. Of course, verizon no longer sells it--probably for this very reason. Good luck & just keep the phone as "still" as you can when it's charging. Oh, and I have the charger cradle--that was the first thing to GO as far as charging. I WON'T WORK AT ALL....
Posted on Dec 03, 2010
Gz one boulder will not turn back on..it quit on me one day and iv chaged it and it stl ownt turn on
I am re-posting the following answer from a similar question..
Connect to the charger just long enough for the screen to power on, then immediately disconnect the charger before it goes into charging mode. . -- It should power up and be ready for use.in a couple seconds.
I have found that only when the battery gets completely drained, that the Gzone Rock often will not power back up on it's own, even though the battery has been successfully recharged.
By connecting the to the charger it will initiate the boot-up of the phone - but you must remove it before it displays the charging screen again, otherwise it still won't come on and boot.
Sep 10, 2011 | Casio G'zOne Rock Cell Phone
The charge port on my Casio Boulder does not work anymore is there a place I can send it to have it repaired?
Try your local corporate carrier's store. Most corporate locations have repair on site and some even replace the device on site if it is less than a year old.
Franchise locations usually do not follow the above practices.
Mar 09, 2011 | Casio G'zOne Boulder Cell Phone
The charger port on my g zone boulder came out
you can get a dock to charge it on..u will need your wall charger and it plugs into the desktop charger/dock/cradle or whatever u wanna call it. Then u bypass the need for a port. Bad thing is u cant use the car charger easily without taking the dock with u in the car/but can be done! I am looking for replacement ports for casio phones..if anyone knows where u can buy them?
Dec 12, 2010 | Casio G'zOne Boulder Cell Phone
I want to unlock casio g'zone boulder and want to use it in india. is it possible to unlock and use gsm on it?
i want to unlock casio g'zone boulder and want to use it in india. is it possible to unlock and use gsm on it? i happened to hear that g'zone boulder is a cdma phone and it does not accept sim card. is it true??
Oct 14, 2010 | Casio G'zOne Boulder Cell Phone
My casio boulder will not charge how do I fix it
Take care.
Jun 15, 2010 | Casio G'zOne Boulder Cell Phone
Will not charge
Jul 28, 2009 | Casio G'zOne Boulder Cell Phone
My Gz One Boulder's charger port broke off. I
The same thing happened to my Gz One Boulder. I sent it back to Verizon for replacement. The 2nd Gz One Boulder also had problems with the charging port within 2 weeks after I got it so I sent it back too.
I am now on my 3rd Gz One Boulder. I've only had it 2 days. Time will tell if the charging port on this one will hold up. Frankly I doubt it.
My best advise to you is get a different phone if you have the opportunity to do so.
Jul 27, 2009 | Casio G''zOne Type S Cellular Phone
Need to turn off certain features on Verizon- Casio Boulder GzOne
access your account online and block all of those things in your plan options, or you can call verizon wireless and tell them all the things that you listed here and they will have your phone block them
Jul 26, 2009 | Casio G'zOne Boulder Cell Phone
Casio G'zOne Boulder Cell Phone Logo
922 people viewed this question
Top Casio Cell Phones Experts
Sameer Raut
Sameer Raut
Sean Burke
Sean Burke
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
