Question about Goodman CLQ30AR32 Air Conditioner
I have a Goodman GSC130361DE it is too small for a 2100sq ft home
I have a Goodman GSC130361DE it is about 2 years old. My house is 2100sq ft. Since I bought the house I have noticed the AC does not cool properly. I had an AC company come over and check it and they said the AC was fine. I had a second company come and they said the unit was too small for the house. Is the unit really too small for the house?
  • 70 Answers
Well you have a 3 ton system, it might be a tick small depending on windows and insulation in the house. Make sure you set it at one temp and leave it. Zoneing would also help.
Posted on Jul 17, 2010
  • 407 Answers
Both companies can be right at the same time and I will explain this. You have a 3 ton system, going by the model number you have given. For every 1 ton of air, you get an average of 400 cfm. That is 1200 cfm for your system. You need an average of 1 cfm per square foot, that's the basic way to calculate a residential system. So, if your house is 2100 sq ft, you need at least 2100 cfms, which is a 5 ton unit. That is were the company that says it's to small gets there diagnosis, on the other hand, with a unit that is to small, it can still operate the way it's supposed to and the company that says it's fine is probably going off of the way the unit is ''technically'' working. Things to consider though before you come to an conclusion, when you say that your house is 2100 sq ft, the unit only needs to be based on square footage of "living space". The best way to do this is to go to each room where there is a supply register and get the sq ft of each room, it might be smaller than 2100 sq ft. A lot of people, when selling a home, will include the garage and other "non living" spaces in the square footage. Other things to consider are the heat loads of each room, meaning how many windows, doors, etc. Depending on the heat loads, the placement of the registers, and your duct work, you can have the right sized system and still not get the performance it's meant to have. The problem still remains that your not happy with the system's performance and that's the important thing, unfortunately, it might be a lot bigger of a problem than you thought. Hope this helps and good luck!
Goodman AC unit recently service but don't believe the filter I am using is the issue or what the tech did actually fixed my issue. Details below.
Setting the air handler to high speed will draw more current and this will result in an increase in electricity consumption.
Jul 27, 2017 | Goodman Heating & Cooling
I am new homeowner of 60+ small ranch 1,000 sq ft. Home has 2010 Goodman gas furnace set into existing ductwork previously used for coal/wood furnace. Blows hot air into 2 cold air returns. HVAC man...
Look closely at the ductwork; determine which is your returns and which is your supply, and also check for" old baffles "that may be diverting your supply air into a return.
On the outside of the duck work you will see a wingnut or some have small handles that indicate the placement of the baffle and in the direction it is facing (vertical) will mean it shut off (horizontal) will mean that it is letting air pass through. If they're working properly and not loose.
It sounds like they had the old furnaces Duck work is in a loop for part of the home to recirculate the air that was heated .
that would be my guess without looking at it .
I hope this helps you, look in the right direction it's definitely duck work that is causing your problem.
Also get Mastick and UL ratedtape from your local hardware store to patch holes and cracks Old ductwork.
that will help You with the efficiency of your furnace.
Oct 16, 2014 | Goodman Heating & Cooling
How do i find out the year my a/c unit was built?goodman a/c unit ?
Year model is the first 2 numbers in the serial number on the placard.
Aug 23, 2014 | Goodman Heating & Cooling
Where can I find the specs for an earlier Goodman heat pump?
You say 2 to 3 years... I'm assuming the unit is older than that. Especially being r22. What about the first 10 years??? Normally you will get 400 to 500 sqft per ton of cooling, but, that depends on heat load calculations. If the unit wasn't big enough you would have had this issue 10 years ago, not when the system kept running low on refrigerant. At first guess I would say a 2 ton unit is not big enough but if it worked fine for 10 years...wuth all that in mind, if it were me, (a seasoned professional) I would spend 1800 to fix my 15 year old r22 unit before I spent $4000 on a new r410a piece of junk. Best Wishes!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 29, 2017 | Goodman GMS90703BXA Heater
How can I make the ac quieter inside the house?
If you have hard ducts, you can use some flex duct between the supply plenum and the hard ducts as a way to quiet the noise down.
May 10, 2017 | Goodman Heating & Cooling
My AC unit model is CPLE60-1. It is running, blowing cool air but not cooling house. Any Suggestions? and what is the life expectancy of this unit?
Your Goodman unit is a five ton and should last 15 to 10 years with proper maintenance. Parts do wear out though during the normal life of piece of equipment.
Cooling problem may be due to low charge, broken ducting, or other low airflow problem. Need to verify freon charge and then go from there.
Jul 27, 2011 | Goodman CKL36AR36 Air Conditioner
Goodman ck36 1b a/c. Capacitor replaced 2 years ago. Unit is 13 years old and thermostat is Honeywell, also 13 years old. This summer there seems to be a 3-5 min delay (from when thermostat registers call)...
If you have a AC unit with electric or gas its doing what its supposed to do, let the pressures in the system equilize before starting again, If you have a heat pump its doing it there as well you just have not noticed. Anti cycling is a good thing, 4 to 5 minutes is normal.
Jul 05, 2011 | Goodman Heating & Cooling
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
Goodman CLQ30AR32 Air Conditioner Logo
1,730 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
