2008 Kia Optima Logo
Posted on Jul 17, 2010
I have a 2008 Kia optima that I need to find out how to adjust the headlights, they are aimed too low to the ground, can't see at night
Anonymous
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Jul 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
17519
Points
93
Look on dashboard for a switch with headlamp symbol on it possibly arrows on it too,and it will have 3 or 4 settings on the switch 1 being the highest setting and the lowest setting being the lowest number. if set to 1 and still too low the open bonnet and look for adjusting scres on backs of headlamp or on top of headlamp usually hexagon drive or posi drive some even have little thumbwheels on for easy adjustment. take care though one screw alters vertical movement and the other adjusts left / right aim
1helpful
I need the location of the adjustments for the lower beam on a 2007 Kia Optima. The manual shows one, and it IS labeled lower beam in the book, but that adjustment moves the high beam.
there is a bolt on the back of the housing, 8 or 10mm that adjusts the low beam up and down. I hated the aiming of the low beam headlights too
How do I adjust my Kia car headlights for driving in France.
LET DEALERSHIP OR GARAGE FIX IT.BECAUSE THEY HAVE EQUIPMENT TO ADJUST THE HEADLIGHTS.IF YOU TRY ADJUSTING THEM WITH OUT EQUIPMENT.YOUR HEADLIGHTS WILL BLIND OTHER DRIVERS ON THE OPPOSITE LANE.
12helpful
Headlight pointing down, loose in housing
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
10helpful
My headlights need adjusting on my 2009 Ford Focus. Then point too low and have no night vision
9helpful
2answers
Opel astra headlight adjustment
two screws on each headlight control the direction the headlights are aimed. One screw, usually at the top but sometimes below the headlight, adjusts the headlight up and down. The other screw, located to one side, controls the headlight from right to left. Turning the appropriate screw one direction or the other will change the direction the headlight points.
In order to aim your headlights you need to have a flat vertical surface you can aim your headlights at in front of a level surface on which to park the car. If your driveway is level your garage door is the perfect place to aim your headlights.
The tools you will need for this job are simple. Masking tape is used to mark where the headlights are to be aimed and a screwdriver is needed to adjust the headlights. A tape measure will be necessary to measure the distance of the vehicle to the surface you're using to check the aim and to measure the up and down distances from your marks
7helpful
How do i adjust headlights on kia optima 2003
2helpful
2answers
Can't find the adjustment knob for the headlights on a 2008 Mazda
4helpful
I replaced the headlight assemblies with eagle eye headlights How do I adjust the headlights. One shines up in the trees as if I was con hunting
25helpful
4answers
2006 Kia Optima headlight adjustment
I posted the adjustment directions here.
http://www.fixya.com/cars/t1481698-head_light_adjustment_2004_optima
2helpful
Headlight
on each headlamp assembly, there will be either one or two plastic nuts that you can turn.
If you only have one nut on each, that will adjust the vertical aim of the headlights.
If you have two nuts on each, one will adjust the vertical and the other will adjust the horizontal.
Top Kia Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Kia Expert? Answer questions, earn points and help others
