Question about Dishwashers
Loud vibrating/humming noise
Of course the dishwasher is just over 1 year old and I am hearing something I have either never heard before or, if I did, it wasn't this loud. While the dishwasher is draining (I know because I am hearing water in my garbage disposal) I hear a rather loud humming/vibrating sound. This happens a few times during the normal cycle as well as the Eco wash cycle. The dishes are coming out clean, dry and there is no water left on the bottom of the unit when I open the door. I am concerned because I was surprised at how quiet the dishwasher was when we first got it. It even boasts about being quieter than other dishwashers. Any suggestions or ideas as to why? My husband took off the bottom and ran a cycle, the noise sounds like it is coming from the pump assembly( which is not hitting the floor). What do you think it could be? What could we check next? This is the loudest noise coming from the dishwasher during a cycle, is that common? Sharon
  • 2 more comments
  • Rena450 Apr 21, 2008
    No, he did not pull the pump, he just made sure it wasn't resting on the floor and vibrating. The model # is PLD4375RFCO. It was purchased February 2007 and I started to hear the noise in March of this year. I really appreciate your help.
  • lfarmer2005 Aug 28, 2008
    i have the same one and for some reason it just stopped working properly. i put the dishes in there and I didn't hear any water running like I did before. When it was done I opened it up and the dishwashing tablet was laying in the bottom of the dishwasher.
  • gnice Nov 24, 2008
    we are experiencing a similar problem with a 6 year old 7910. Quiet until today.Suddenly making a horrendous vibration humming sound periodically while filling and changing cycle. otherwise ok.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Did your husband pull the pump and check for obstructions? It is common for debris such as toothpicks, popcorn kernels and chicken bones to get caught in the drain pump impeller, drain sump, or chopper assembly (if your dishwasher is equipped). Please post back with your model number, so I can be sure.
  • 5,911 Answers
Okay...based on the model number, this is a Frigidaire manufactured dishwasher. If you go to searspartsdirect.com and type in the your model number in the Search menu, you will find a useful illustration under the "Motor and Pump" heading. The drain pump is listed as item #60 in the drawing. Before you go through any major dis-assembly, check to make sure the pump is securely in place and not loose. Sometimes the pump comes loose from the mounting bracket and vibrates. Also, sure nothing is laying against it causing vibration noises (I've seen this before). If the solution is not that simple, remove the spray arm assembly inside the dishwasher and inspect all the debris traps under the spray arm assembly. The wash pump and drain pump sumps are located here. Check to make sure there's nothing obstructing the input to the drain pump. Lastly, if all else fails, remove the drain pump and inspect the impeller. If the you've inspected everything and still have the noise problem, replace the drain pump. The motor could possible be failing. The part number on the Sears website is 154580301 and costs about $40. Repairclinic.com has the same part listed as item #1257094 for $37.50 if you wish to do some comparable pricing.
I hope this helps you. If you need further assistance, please post back and let me know.
PS Even the quietest of all dishwashers will make some noise. However, if it has gotten to the point where you can hear it in the next room, you probably need to inspect to find the source of the problem. This is not true with all dishwasher manufacturers, but in many cases, the only difference between your "Quiet-Pack" line and regular low-end models is added insulation behind the door and lower panel to help quieten noise.
Posted on Apr 21, 2008
2 Suggested Answers
  • 220 Answers
SOURCE: My Whirlpool Quiet Partner III is collecting dirty
The drain hose under the sink needs to be tied up,above the point where it enters the drain pipe or disposal,water is feeding back into the unit,run the disposal more often also this helps prevent this from happening.
Posted on Sep 01, 2009
Why does it make a loud Humming noise?
Something is still in the main wash pump, you hear the motor trying to turn the impeller and it can not
Mar 27, 2016 | Dishwashers
Loud humming dyson DC07
Hi Phil,
I apologize for our delayed response. I am sorry to hear you are experiencing an unusual noise when you initially run your DC07. Based on the details you provided we would appreciate the opportunity to trouble shoot with you over the phone so we can also hear the noise to better determine next steps.
At your earliest convenience, please call us directly at 0800 298 0298 (UK) or 1-866-693-9766 (UK). We look forward to speaking with you.
Best wishes,
Jessica
Nov 28, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
Ilo DVDR05 Vibration and loud humming noise
i experienced that problem before.one cause is the cd itself.there cd's that are too thick so the motor has hard time rotating that makes vibrating sound.the other ,don't put something over your unit.the cover is touching the holder of the cd and makes a sound.just do the necessary things to be done like don't put something on top your unit.if not, then a manual analysis of the tech is the last option.
May 17, 2009 | iLO DVDR05 DVD Recorder
Loud Humming noise every time we run the dishwasher
Hi, I had this exact same problem. In my situation it turned out to be the pump that pumps out all of the used water. It was rubbing up against the floor so that every time it turned on it made a loud vibrating sound. I just reached under the washer and put a piece of rubber between it and the floor and it solved the problem.
good luck!
I saw this post because I am considering buying the same model you have. Other than the noise problem you have, what do you think of it?
Mar 29, 2009 | Jenn-Air Dishwashers
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Heat pump is humming loud>
When the heat is not on. Go to the T-stat and turn the fan to the on position. With the blower now running is it making the noise? If so you probably either have something in there such as the filter that was mentioned, a piece of paper etc. or one or more of the blades on the blower wheel is vibrating. Don't let the condition persist w/o having it checked out or you may turn a simple fix into a costly one.
Jan 22, 2009 | Heating & Cooling
1 week after installation- is very loud
dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Nov 06, 2007 | Soyo Dymond DYLT037A Television
Maytage dishwasher
Hi Fix it mom, If your courageous, pull the trays out of the way and remove the screen in bottom of the dishwasher to see if something is getting into the pump. By something I mean undesired matter. Straw, Twist tie, knife, toothpick, etc... I hope this helps
Sep 25, 2007 | Maytag 24 in. MDB4651A Built-in Dishwasher
Dishwashers Logo
1,516 people viewed this question
Top Dishwashers Experts
