LG Washing Machine WD - 1049C The machine is in a wash cycle and is stuck on 13 (I'm assuming minutes). Four days old. Whats the problem?
  • gugsm Nov 25, 2008
    yes. this is the 2nd machine and it gets stuck in the rinse cycle .. 9 mins. left. former machine stuck at 18 mins
  • 101 Answers
The problem is you timer needs to be replace. The timer is getting stuck at that point.
Posted on Apr 21, 2008
Mine has done the same thing brushes needed replacing in mine you have to buy a new motor or find someone who has an old motor from same model to replace brushes we did that
Posted on Nov 17, 2012
Cant open door on LG front loader wc-1049c HELP
Posted on Aug 25, 2009
  • Derrick Watson
    Derrick Watson Mar 26, 2014
    unplug the washing machine door will release after a few minutes
I have a LG front loader WD-1049C it's 6 yrs old And has just started to make a loud noise while in spin cycle All other cycles are fine
If the washer is making a loud noise the tub bearing might need to be replaced. This is a very involved repair and will require disassembling most of the washer. The manufacturer recommends that if possible the complete outer tub and bearing be replaced rather than attempting to replace just the bearing in the tub. If the bearing is bad the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine
Feb 19, 2015 | LG Washing Machines
Why does my LG WD-1049C washing machine get stuck when doing a wash cycle?
first thing to check is the carbon brushes,cheapest fix too.they wear down after a time and need to be replaced,check see if they are worn out
Mar 12, 2013 | Washing Machines
Where is the lint collector on LG 7.5g model WD 1049C Front Loader washing machine.
The combo washer/dryer doesn't have a lint collector. Air is circulated through a condensate tube and is washed down during each drying cycle.
Jun 16, 2011 | Washing Machines
LG wd 1049c washing machine doesn't spin out stops on 13 minutes. Is there a trouble shooting technique that can be used?
We have had exactly the same problem with our machine. Had a tech come out and he said that it is a problem with the main motor which needs to be replaced. Still waiting to hear from them re cost of part, but did a search and found one online for around $211. Should be intresting to find out how much it will cost with labour etc.
Jan 01, 2011 | Washing Machines
Hi. My LG 7.5kg Front Loader Washing Machine WD-1049C does not spin. It washes the clothes ok but fails to go into the spin cycle. The fault code UE comes up if i let it bumble through the cycle long...
Im soory to have to tell you this but i belive it is mostlikley the motor control board and it is worth a couple hundred dollars plus lobour it is the board benith the durm in the front right corner i hope im wrong on this i bet your clother are stuck in there with the door locked full of water there is a trick to draim then unlock the door by pushing in 2 buttons at the some time but i cant think of it right now ill try to post that trick if i recall it latter hope this helped
Aug 20, 2010 | LG WM-12230FB Front Load Washer
LG WD-1049C Front Load Washing Machine Pump impeller sloppy
probably better change the pump if you feel any up and down slack in the impellor. you may have an ingress of water through the seal.
Mar 13, 2009 | LG WD-1045FH Front Load Washer
Washing Machines Logo
1,113 people viewed this question
Top Washing Machines Experts
