Hello good day printer is saying service transfer unit with error code 90400 machine is totally serviced and vacuumed yet code is still there can you give me the diagonistic code to clear this error.
    President:
  • 567 Answers
Hi please uninstall the drivers for the printer and reinstall them again,then restart the computer and see if the error still exist.
Please let me know if you have any questions
Posted on Jul 17, 2010
To printer 4025
you need to go where it says Service then input that code and scroll to reset the belt. ( this only needs to be reset in Service mode when changing before the counter says to.)
Dec 05, 2016 | HP LaserJet Office Equipment & Supplies
How can I resolve error code C-2451
Release new transfer belt unit
• A new installation is not detected when a new transfer cleaner unit (image transfer belt unit) is installed. Remedy 1 Reinstall unit. 2 Check there is a short circuit in the fuse of the transfer belt unit. 3 Check the PRCB connector for proper connection and correct as necessary. 4 Change PRCB
Feb 02, 2015 | Konica Minolta Bizhub C550
Tk2 error
TK2 is for the secondary transfer unit located on the side door. The code will come on after a certain number of total prints, depending on the model. Enter service mode by pressing # * C *, enter number 24 and press the copy button, then enter number 4 and press copy. Highlight everything that says TC2 and press execute on the touch screen. CA will reboot.
Sep 07, 2012 | Sharp Office Equipment & Supplies
Please call service 003
If the machine is saying "Please Call Service"..You will have to access the Service Call function to determine the exact problem.
Press PROG,*,6
Press PROG to select "service call" mode, then press ENTER.
The Error Message will be displayed.
For example Heater Error, Drum Fuse Error, Inside Fan Error, etc, etc...
**Most common (given m/c age.) would be "Heater Error"...which indicates a problem with the Fuser Unit.....if this is the case you will need to contact local Muratec service for parts
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 22, 2010 | Muratec Copier
Konica minalota 210 error code detials can everyone can give me the error code
If you are asking about a C0 210 code on a Minolta Di183 then this code means there has been a abnormal image transfer voltage error. The service manual says "the image transfer voltage remains more than 100V for a continuous given period of time while the PC drum remains stationary".
Have you opened/closed the front door or turned the machine off then back on to reset the code and see if it returns?
27 years working on Minolta copiers and I have never seen this code on this model of machine before so hopefully it will reset. If not you will need to call for service on the machine.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Konica Minolta DiALTA Di183F Copier
What is the error 59.99
that error is not encountered in the service manual, contact me t walid_sayed@ hotmai.com and I wil send you the service manual for FREE
regards
walid sayed
Mar 22, 2010 | HP Color LaserJet 3500 Printer
Konica Minoltra Bizhub C250 Malfunction detected C-2451 This message I got after I changed fuse on transfer unit. How to solve it, or at least what this error code means?
hi, from the service manual:
C2451:
Item:
Transfer Cleaner Unit New
Article Release
Description:
Transfer Cleaner Unit (Image Transfer Belt Unit) is
installed.
for the solution, SM says you should try refitting Transfer Cleaner Unit(misplacing could occur) or change the PWB-M board.
Feb 09, 2010 | Konica Minolta bizhub C250 All-In-One...
Please show me how can I unlock the error code SC305 for Photocopier Ricoh Aficio 1224c
This is a Corona cleaning unit error. You either need to get the issue with the corona cleaning unit fixed or have a service technician turn off the automatic cleaning function. SP Mode 2 801 3 (technican will know what this code means) I can not tell you how to do this as you can total mess up the machine if the service mode is not used properly.
Turning off the cleaning will solve the error code. Technician can clean the coronas himself on service calls so automatic cleaning is not required.
Good Luck
Dec 07, 2009 | Ricoh Aficio 2015 Copier
Code Error 6A80
6A80 error is an APP position error. It means that an error has occured when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Oct 20, 2009 | Canon MX700 Office All-In-One InkJet...
Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Mar 07, 2008 | Computers & Internet
k24674
jasbo
jasbo
Marvin
Marvin
