Question about Pioneer AVD-W6200 6.5 in. Car Monitor
Ref: avd w6200. 2004 Motorhome installation. Acts like loose connection when traveling but not always. Picture appears like a week signal, dim and sometimes goes off, no picture. Is there something needs replaced? I found a part that is connected, No:ISO MAX. Discovered tipping screen backwards seems to brighten the picture. Seems we have always had some of this problem since 2004. Appreciate help Thanks so much, Myron Warner Rome City,IN 46784
  • myronwarner Jul 17, 2010
    NEED ADVISE FROM ANOTHER EXPERT.
    THANK YOU
  • myronwarner Jul 25, 2010
    THANK YOU,
    WHERE DO I FIND THE PICTURE BOARD. MY ZIP 46784
    ROME CITY, IN.
    Genius:
  • 1,478 Answers
I think the problem with your monitor is that, the picture board on the monitor is malfunctioning that is why it keeps losing signal and goes off or did mot display picture.
What you need to do is to replace the picture board on your LCD monitor, replacing the picture board will solve the problem, because the picture board on the monitor at the moment is bad and will need to be replace.
Replace the picture board and you will see that the problem will not repeat itself again.
Take care.
Posted on Jul 25, 2010
  • Jimoh Adeleke Muyideen Jul 25, 2010
    Go to any computer accessories shop to get the board or it will be better if you can get local any repairer within your vicinity
    to help with the replacement of the picture board.
    Take care.
    Guru:
  • 632 Answers
This sounds like a problem with the flat wire connecting the motherboard inside the monitor, Replace the cable which will cost around a few dollars and it will be back working.
Posted on Jul 17, 2010
  • 6,826 Answers
Actually, lcd screens when tilted do appear lighter or darker depending on the angle of viewing. Also, the ntsc signal you get through your antenna may vary in strength and make the picture completely go out if you are in a weak signal area, such as a small town vs. the big city where broadcasters are concentrated. HDTV signals can be horrible in this way in outlying areas.
Dimmer Function: You can select the brightness level from High, Medium or Low settings. Furthermore, if the Illumination wire is connected to the vehicle's headlight circuit, the display will automatically dim when the headlights are turned on. You can store different brightness/dimmer settings for each source.
Monitor Adjustments: You can make the following picture adjustments to the monitor:
  • Brightness: You can make black appear darker or lighter (-24 to +24).
  • Contrast: You can narrow or widen the gap between black and white (-24 to +24).
  • Color: You can make colors appear lighter or darker (-24 to +24).
  • Hue: You can adjust the red or green of the picture (-24 to +24).
Note: These settings are stored by the source (Video 1/Video 2) and the lighting switch (Car lights on/off)
  • Duane Wong
    Duane Wong Jul 17, 2010
    All hdtv units that rely on over the air broadcasts will experience technical difficulties in fringe areas.
    I experience this with my full size hdtv in Somerset, PA where Johnstown (30 mi. away) is the nearest transmitter.
    And, I'm not even in a mobile vehicle with that installation.
    I wish you luck in fixing this problem.
  • Duane Wong
    Duane Wong Jul 22, 2010
    Is the display so dark all of the time as if the 'circuit control' for having it connected to the parking brake or shift lever (Park) is not connected right? There is a feature on this monitor that will not allow you to use it normally if you are determined to be on the road with it. It's that way to prevent distractions, I think, for the driver.
Do you want hints & tips on Motorhome problems?
not really unless you want to answer questions on here for free
Nov 29, 2012 | Cars & Trucks
Front turn signals work intermittently, side signals work as well as the rear
Loose connection at the sockets or joints. Check bulb seating at sockets (new sockets can be loose-Fong Kong) and clean cable connections
Nov 06, 2012 | 1997 Oldsmobile Silhouette
My dvd player has sound but no picture, only blue screen, how can i fix this?, model Futronic AVD-888T.
Does anybody have a remote for A Futronic AVD 888 T DVD player. If yes please contact me at : taumokala@gmail.com. I will pay for it
Nov 16, 2010 | Televison & Video
I have recently purchased a G1301E unit. Upon installing the unit in my Fiat Ducato 2.8 Diesel Motorhome, everything works OK apart from as soon as I start the engine I loose all sound, no music from the...
You may have got the wiring wrong for the Power
it has one power and one for connecting to headlight power Which when headlights on it will illuminate the radio more/less depending on manufacture.
Mixing these up could mean soon as you start its thinking it needs to dim screen but instead its dimming the power.
Aug 11, 2010 | Car Audio & Video
No sound on my AVD-S10 CD/DVD reciever.
just check up your rca chord maybe loose connection or defective rca chord. in audio only
Jun 19, 2010 | Sony AVD-S10 DVD Player
1995 Saab 900 Same problem with stalls dies no warning
It appears to me to be more of a loose or damaged battery or ground connection, either on the battery, the starter, or a power wire somewhere. Next time you have dim lights, get under the hood and wiggle wires around, to see if you can get them to brighten up. When you do hit the right wire, you'll find the problem.
Dec 01, 2009 | 1994 Saab 900
CD's won't play in Jensen VR185
Do you have it set on mp3
Aug 11, 2009 | Car Audio & Video
Plasma TV Fault
What is the make and model #?
Jan 14, 2008 | RCA L46WD22 Television
Toshiba 36A42 TV. Dim Picture
Check the "screen" control on the flyback (lower knob) its easy to hit moving a board around. Try to adjust back to its original setting. Look for where the dust is, it should be on top. Or any marks might help. Other wise adjust slowly, back off if any retrace lines appear, with user settings at there normal settings.
Oct 27, 2007 | Toshiba 27AF42 27" TV
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
Pioneer AVD-W6200 6.5 in. Car Monitor Logo
62 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
