Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Do not disturb feature has been activated. our unit does not have such a button to turn on or off. unable to deactivate.
  • drmrsmel Jul 17, 2010
    the volume is fine. whenever someone calls the house phone, it says that the do not disturb feature has been activated. we are able to make calls but not able to receive them. we do not know how this feature was activated.
    Brigadier General:
  • 7,191 Answers
Please let us know the complete model number of the phone.
Kindly reply with the details to this post. Thanks for using FixYa.
Posted on Jul 17, 2010
  • 2 more comments
    the model number is DECT 1580-4WXT
    the model is DECT 1580-4WXT
  • AliTech110
    AliTech110 Jul 17, 2010
    Many thanks for the reply.
    This phone has 4 ringer volume settings (off, low, medium, and high)
    So, if your phone ringer has been set to the "Off" mode, you can adjust the ring volume by pressing the "Volume +" button or the Up arrow button on the handset.
    Use the Up Arrow button on the handset or VOLUME + button on the base to make the ringer volume louder.
    Thanks again.
  • AliTech110
    With the phone in the stand by mode, press the Up arrow key on the handset and Volume + key on the base to increase the ring volume. (See attached image)
    Thanks
When someone calls messae says' not accepting calls' how do i turn this off
Does this happen on all inbound calls or just some?
If this is on all inbound calls...Sounds like Do not disturb is turned on. Most uniden's have a DND (do not disturb) mode. Try turning this off and see if that helps.
Using Do Not Disturb
  • The Do Not Disturb or DND feature turns off the audio ringers of the base and all handsets at the same time. It does not affect any of the visual ringers.
  • With the phone in standby, press and hold Do not Disturb on the base. The phone automatically turns on the answering system and shows Do Not Disturb in the display on all handsets.
  • To cancel, press Do not Disturb.
If this is not the issue, it may be turned on at the central office (your phone company) try using the DND activation/deactivation code of *64 from your phone.
If this is just on some inbound calls...Then it you may have anonymous call rejection turned on. That feature blocks calls from people that block their calling number when placing calls.
Mar 01, 2012 | Uniden DECT 6.0 Cordless Phone ID
I have a Craftsman opener with security plus (18 months old-blak transmitter button) and the wireless keypad will open the door by simply hitting enter (no code required). I would assume it had to be the...
Opener can be closed by pressing only the ENTER button if the One Button Close feature has been activated. This feature has been activated at the factory. To activate or deactivate this feature press and hold buttons 1 and 9 for 10 seconds. The keypad will blink twice when the One Button Close is activated. The keypad will blink 4 times when One Button Close is deactivated.
Aug 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Program "Do not disturb" on business phone
It's pretty straightforward. You pick a spare button, dial FEAT 00 press the blank button (with a light) and press FEAT 01. There are considerations that I'll reproduce here.
Do Not Disturb (F01) 8
Use this feature to be able to press a programmed button to prevent incoming calls for the
extension from ringing (lights still flash). When Do Not Disturb is on, outside callers hear ringing
while inside callers hear a busy signal. You should use Do Not Disturb only if someone answers
outside calls for your extension when you do not answer them.
Considerations 8
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
■ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
■ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
■ To avoid missing calls when Do Not Disturb is not needed, turn it off.
■ If Do Not Disturb is active at a doorphone alert extension, the person at the doorphone hears
signaling, but the alert extension is not signaled.
■ Unanswered calls that are transferred from an extension with Do Not Disturb active ring at
that extension if they transfer return.
■ Extensions with Do Not Disturb activated do not receive Caller ID information, unless the call
is answered.
■ Users with Automatic VMS Cover Assigned or with VMS Cover turned on can activate Do
Not Disturb
to Send All Calls immediately to their voice mailbox.
■ Users with Call Coverage turned on can activate Do Not Disturb to Send All Calls
immediately to the covering extension.
■ You cannot use Call Screening (F25) when Do Not Disturb is turned on.
Carl
May 10, 2010 | Lands Phones
Keypad on garage door will only close if i punch in my code it won't close by hitting the enter button the temp here is minus 40 does that effect the keypad chamberlain 3/4 belt drive
Try this procedure to reactivate this feature.
Dec 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Unable to transfer calls to a certain internal extension using a M7310 Nortel Corded phone
The do not disturb might be active on the extension that your trying to transfer to.On the extension that your trying to transfer to, enter feature #85 to cancel out do not disturb.
Sep 28, 2009 | Nortel Meridian M7208 Corded Phone
00:DND showing on the screen, and the Feature light is blinking. Manual does not have a troubleshooting guide.
I found that pressing Feature -> 99 -> Feature cleared it up. The Do Not Disturb option does not work either with what the owner's manual states, or the company's Website, to either activate it or deactivate.
Aug 04, 2009 | NEC DTU 8D-2 Corded Phone
Deactivating Do Not Disturb command
I loosely followed Solution #2's answer. If you pick up the phone, the display screen will show options above each of the 4 'arrow' buttons. The one to the far right, for me anyway, showed something looking like this: >>>
I hit it and it showed a number of options, one being "DND". Hitting that deactivated (or activated) DND on the phone I was currently on. That solved the problem for me.
Jul 27, 2009 | NEC Dterm DTP-2DT-1 Phone
"Do Not Disturb"
On the base unit, press the "Do Not Disturb" button. This button is located on the front right corner of the base unit. The button light should turn off indicating that the DND feature is deactivated.
Feb 05, 2008 | GE 25952 Cordless Phone
NEC DTH16D-1
Press Feature 69 Feature to turn off the do not disturb. Feature 60 Feature turns it on.
Sep 25, 2007 | NEC Electra Elite 32D-1 Corded Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
91 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
