Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Black decker lawn mower mm1800 trip my circuit
My black decker lawn mower mm1800 trip my circuit breaker. pls help.
3 Suggested Answers
  • 313 Answers
SOURCE: Mower tripped outlet breaker - wiring schematic available?
electrical diagram available i send it to your email just give your email add.
Posted on Jun 16, 2008
jmgldsmth
  • 2005 Answers
SOURCE: electric lawn mower slowed down then stopped working?
The carbon brushes on your mower have worn and, need to be replaced; order them from black & decker
Posted on May 21, 2009
Black and decker electric mower hums but blade does not turn. appears the brake is not releasing for the blade.
Something has the motor unable to turn. Do not turn on till you locate the source of the problem lest you burn it out.
Aug 02, 2016 | Black and Decker USA Black & Decker MM1800...
My MM1800 started to smoke?
Return it to the retailer for service. it presumably has a warranty that the supplier is obliged to honour. As long as they do not argue that you were somehow not using the device in the manner it was intended you should have no problems. The retailer should, in any case, contact the manufacturer for authorisation to repair or replace.
Jun 03, 2015 | Black and Decker USA Black & Decker MM1800...
There is a short somewhere. It keeps popping the circuit breaker.
If the cable is in good condition chances are the motor has had it. Time for a new mower.
Aug 03, 2014 | Black & Decker Black Decker 18" Lawnhog...
No start on a mm 1800 18"
check the cord for cuts then check the safty engagement on the handle and make sure it disengages to cut thats about all you can do turn blade make sure turn freely not plug in after you will have to take it in
May 31, 2014 | Black & Decker Black and Decker Mm575 18"...
I have a Black and Decker Electric Lawn Mower MM525. Trips breaker when I start it.Was working great,Started it again and now it trips breaker. Mike
the brushes in the motor may be shorting out. check or replace the motor brushes. be sure cord is not the problem.and check the plug also. good-day !
Oct 16, 2011 | Black & Decker 19" Electric Lawnhog...
My lawn mower just stopped working. I was mowing along and it just stopped. It is an electric Black and decker. I was mowing regular grass, nothing complex. It was working fine before that. It is very new...
Open your circuit breaker box. Locate the breaker that has tripped. Turn the breaker OFF (it is in a mid position). Then turn it back ON. Before you do that you need to ask yourself, why did the circuit breaker trip? They trip because of an overload of current. Is something else running on that same circuit, say for example an electric heater or something similar? Depending on the rating of that circuit breaker (15 or 20 amps) you may be drawing too much current. Look for anything else that could be running on the same circuit (only so many outlets can be put on the same circuit). Disconnect or turn off all other devices. Attempt to operate your mower again. If the breaker trips again, then there is something wrong with your mower (electrical short?).
Nov 29, 2017 | Electric Lawn Mower
When I pull the red lever on the electic mower, the lawnmower will not start and the GFI to my house is being popped?
just for a quick test -- run power to the mower using a different outlet,,, GFI outlets are well known for having a bad trip circuit in them,, they go bad all the time. so if your mower does in fact work on a different outlet with no problems then the issue is your GFI outlet and you will need to replace it.
if the mower is infact tripping the next circuit then the problem is with the mower motor windings or a short at the switch or two wires shorting out. check all wires and make sure connections are good.
c...
Jan 30, 2011 | Black & Decker Black Decker 18" Lawnhog...
Replaced switch but circuit breaker trips on start up ! Mowermm600
Your circuit breaker will trip because of two main reasons:
  • Electrical power point circuit is overloaded (too many appliances active on the same power point circuit)
  • Power Lawn mower has become unsafe as your active live is able to reach your earth connection (e.g. short-circuit). Make sure that you have correctly reconnect ALL your power leads wires (check that the Active and Neutral wires have not been transpose). With power off/device unplug, use a multimeter on resistance range and verify that your active lead pin is not showing a reading against the Earth (middle) pin when the mower switch is turn on or off! There should not be any resistance reading between the Earth and Neutral (opposite pin to Active) pins either!
Hope it helps.
Aug 01, 2010 | Black & Decker Garden
Electric lawn mower slowed down then stopped working?
May 21, 2009 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
156 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
