Question about Konica Minolta DiALTA Di1610p Printer
Service call(c14A3) - Konica Minolta DiALTA Di1610p Printer
What can I do when my Konica Minolta bizhub 160 says machine trouble, service call (C14A3)
C14A3 means IR fluorescent lamp fault. Check the Exposure Lamp (LA2) . The Scanner Exposure Lamp fails to turn ON. Test the voltage supply & the Lamp.
Nov 04, 2014 | Konica Minolta bizhub Office Equipment &...
I am getting an error message that says error C14A3. How do i fix it?
The bright that normally come on under the big glass is having issues, replace the scanner assembly can't just get the lamp.
try this web site for starters
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 07, 2014 | Konica Minolta bizhub 161f All-In-One...
I have a 7416MFG which has the Fault (C14A3) does anybody know what that means? THank you
Print head (Where the LASER is located) failure replace the unit.
Apr 28, 2011 | Konica Minolta KonicaMinolta PagePro 4650...
IM GETING A C14A3 SERVICE CALL ON TH SCREEN
This code means your scanner lamp, the one that lights up under the glass is not coming on properly. Usually this code will reset and the machine will work again. In some cases the scan lamp has gone bad and must be replaced.
Aug 17, 2010 | Konica Minolta DiALTA Di1610p Printer
I have a error C14A3
call your nearest technical service representative.
May 31, 2010 | Konica Minolta bizhub 180 All-In-One...
Access service mode on copier docujet 3016F
If you can you will need to get it, the mirrors in the scanning unit.
good luck
Nov 08, 2009 | Office Equipment & Supplies
Hello my printer is saying service call (c14a3) what do i do
Normaly this can be sorted with a reset disc, or try & google a download file.
Nov 06, 2009 | Office Equipment & Supplies
Konica 7415 erro code C14A3
You have a blown exposure lamp or fuse. When repaired code will automaticaly reset.
Oct 15, 2007 | Office Equipment & Supplies
448 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
