Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
I need to replace thread pole for speedylock 1600 what is the part no. And can I buy it thru you? margaret M. Hernandez
  • 10 Answers
SOURCE: white 3-4 thread overlock speedylock model 1600 sewing machine manual needed
Manuals for all types of sewing machines can be downloaded from sewingmanualss.com.
Posted on Jul 31, 2008
  • 9 Answers
SOURCE: Speedylock 1600
Call White at 1-800-331-3164 or go to www.whitesewing.com
Posted on Feb 02, 2009
  • 9 Answers
SOURCE: keeps cutting the thread from inside the machine
Make sure all of your threads are in between the tension dials. Sounds that the machine isn't catching because of the tension. Good Luck
Mimito7
  • 128 Answers
SOURCE: Blades need replacing.
If there is a joann fabrics store nearby, they have them. I think you can also order them online:
www.joann.com
Posted on May 28, 2009
mark24354
  • 776 Answers
SOURCE: My white speedylock 1600 is being difficult.. The
This machine has differential feed (top tension is different from bottom and fabric feed rate can be different from bottom). turn the dials for tension and feed rates to adjust. Adjust bottom tension to tighten bottom threads and possibly speed up bottom feed rate. Tough to say without more info.
Good luck and please rate me.
From White Sewing web site.
"Are wavy fabrics making you seasick? Do puckers leave a sour taste in your mouth? Then you need differential feed. It eliminates distortion and wavy seams when serging knits, plus it prevents puckers and pulled seams on lightweight fabrics. Turn the dial again for instant gathers.
Posted on Nov 23, 2009
Testimonial: "I believe that rethreading it again finally worked.. I did have to change the differential feed which helped alot.. Thank you for your guidance!!"
White speedylock 1600 thread keeps breaking
rethread the machine to make sure it's threaded correctly & that the thread is not caught anywhere
put new needles
check the thread tension, it sounds like it's to tight
use a can of computer air & clean out around the loopers area for lint or loose threads
if none of these suggestions work, then having it serviced would be the next suggestion
Aug 09, 2011 | White Sewing Speedylock 1600 Mechanical...
My white speedylock 1600 is being difficult.. The top threads lay and look perfect.. but the bottom threads are loose.. What can I do about this?
Nov 23, 2009 | White Sewing Speedylock 1600 Mechanical...
White speedylock 7340 loose/missing stitches, up.looper unthreads
All tensions should be on 4. Also, make sure the threading is done correctly. Or if you wish; You can contact me on other sergers for sale. "Best prices guaranteed"! rick_coccia@yahoo.com
May 21, 2009 | White Sewing Speedylock 1600 Mechanical...
Thread keeps breaking
Your machine isn't threaded properly. Check to make sure #1, you have it threaded right and #2 the thread on all 4 spools is in between the tension dials. Good Luck and Hope this helps.
Aug 24, 2008 | White Sewing Speedylock 1600 Mechanical...
White 3-4 thread overlock speedylock model 1600 sewing machine manual needed
Jul 07, 2008 | White Sewing Speedylock 1600 Mechanical...
Keeps cutting the thread from inside the machine
Apr 06, 2008 | White Sewing Speedylock 1600 Mechanical...
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
