Question about HP Computers & Internet
My wife has a new Toshiba laptop with Windows 7. I have a Gateway desktop with Windows XP. The Toshiba will not print using the Gateway as a server. We are using at&t u-verse for our internet access. Firewall has been set to allow sharing. Danny Spurgeon
  • HP Master
  • 4,737 Answers
What is the connection type between the two pc's? Wired or wireless? If it's wireless, will take more time to print. Wired connection is faster. I would suggest you to setup the printer sharing once again from your Xp Gateway. After it's shared, Add the printer from the Toshiba laptop, if you are asked to install the drivers, then go ahead with the installation procedure. There should be no firewall involved with this issue, at least the connection problem and the sharing issue. Please install required drivers and your printer will work fine.
If you have problem, let me know, i am here to assist you further.
Good luck.
Thanks for using FixYa.
Posted on Jul 17, 2010
US-4A Keyspan USB Server
if urs is a 3 in one u wil have scan and copy functions also included in this sir.
is urs a 3 in one?
Jun 21, 2008 | Keyspan USB Server US-4A (d47710) Print...
I have a netgear n150 hooked up to my gateway laptop running windows 7, my gateway laptop running windows xp allows an internet connection but my gateway laptop running vista will not allow a wireless...
There might be a problem w/ your IP address or DNS server, try to open LOCAL AREA NETWORK CONNECTION STATUS in your laptop running xp, click support/details, Then copy the DNS server address and alternative dns server address.
open your vista go to Network Connection/LAN properties, then double click Internet Protocol (TCP/IP, mark obtain ip address automatically, then the lower side Mark USE THE FOLLOWING SEVER ADDRESS then paste the dns server address which you copied from xp laptop. same w/ alternate dns server, and then click OK. DONE.
JUST TRY IF ITS HELP FULL.
Jan 15, 2011 | NetGear WIRELESS-N 150 ACCESS POINT WRLS...
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose your o/s
now run it and presto......
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
MY WINDOWS 7 LAPTOP WONT RECOGNISE PRINT SERVER
Please note that all old devices drivers have upto windows xp or 2003 server files becuase now only windows 7 has been launched in the market. So don't worry you can download print server drivers from the site .
If your print server is USB connected , the windows 7 will say found new hardware after that it will ask you update drivers, there you can click on have disk and locate the driver files where you have kept and clickon windows 2000 or xp from here you can select the driver and install it. Defently your print server will work.
If this answer is helpful ,pls rate it.
Feb 26, 2010 | Office Equipment & Supplies
I am trying to download PCAnywhere 12.0 to windows 7 and it tells me they are not compatible
That is correct Symantec list supported operating systems and Windows 7 is not compatible..
System RequirementsWindows 2000 Professional/Server/Advanced Server
Windows XP Home/Professional (32-bit and 64-bit)
Windows 2003 Server Standard/Enterprise (32-bit and 64-bit)
Windows Vista Ultimate/Business/Enterprise/Home Premium/Home Basic (32-bit and 64-bit)
Windows 2008 Server
Internet Explorer 6.0 or later
Regards
Nov 10, 2009 | Symantec pcAnywhere 12.0 Host & Remote...
How to add my new laptop w/vista to the print server
Visit: http://www.linksysbycisco.com/US/en/support/WPSM54G/download to download the software called (driver) and install it using the Quick Installation right below it.
Aug 16, 2009 | D-Link DPR1260 Rangebooster G...
Can't connect my Linksys WRT54GS router to zonet zps1000
The gateway would be the address that your router uses.
You would plug the print server into the back of the computer using the ethernet line.
Use this link to get into the support section of the website:
http://www.zonetusa.com/index.asp
Dec 30, 2008 | Zonet (ZPS1000) Print Server
Windows Vista home + Windows XP Professional Networking issue
Make sure domain settings to your server are correct on the notebook computer. These settings are located in the control panel of the system setting.
Whats the operating system of your server?
Make sure the firewall in windows security is turned off too. Sometimes that thing sneaks up on you.
I haven't used the home edition of Vista but another reason why it might not be working is because it isn't the business version. Microsoft might have added extra security to prevent the home version from connecting to a server. I know we use the business version of Vista at work and it is working that way on the intranet server without a problem.
I would check with Microsofts website on that.
Jun 21, 2008 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
