Question about Polaroid 1911-TLXB 19 in. LCD TV
The tv was unpluged shows no picture but there is aduio
  • Polaroid Master
  • 8,457 Answers
Now tv turn on.U have a picture flicker for a few sec. than dies,have sound left only.Yes,Than the 1 or 2 long inverter boards are dead.The 1 or 2 long inverter boards are dead.These 1or 2 long inverter boards help the LCD screen to have a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long inverter boards for the replacement.
Posted on Jul 17, 2010
Hi I have a Hisense HLD55v68 and it has no sound picture etc perfect but no sound on either TV or DVD
If you are using a dvi cable you will have to run a seperate audio cable to the flat screen tv input.If you are using hdmi cable then change it.If your using the yell,blu.green cable you need to run a seperate audio cable.Be sure you have the connection to aduio in and not plugged into the audio out on your tv.Try also to get a signal over the air tv and see if you have sound then.If you do you have a connection problem.Bty make sure you have the volume turned up( lolq).If all that still fails the tv is defective.Hopes this helps
Apr 27, 2011 | Televison & Video
Just hooked up a new 47" LED TV to my Blu Ray Home Theater and have no voices played through the speakers. The background music and such is also low but the voices are like a "mute" I just...
You need to verify that the TV on screen audio setuo under HDMI is set to 'AUTO' so it will choose the audio through HDMI port not through the aduio Analog or SPDF/TOSLINK PORT. Check the set up of the DVD HDMI audio setting also.
Dec 02, 2010 | Televison & Video
1 vertical line across the screen maybe 1" tall. It appears to have the entire picture in that short little space.
tv turns its self off i unplug it plug it back in it will flash on not showing picture it u can her it flash on and right back of some times it will not flash in back of tv and i can hit power it will flash and go off every now and then it will come on show picture after being unplugged and plugged back but then shuts off
Jul 16, 2010 | Toshiba 36A50 36" TV
Xbox 360 working thru HDMI working fine. Now no sound & weird pic
it is prolly an internal problem. have to tried connecting the componet cables?
Mar 03, 2010 | Microsoft Xbox 360 Console
I Just connect My pc via 15 pin RGB cable to LG 32R50xx lcd tv,it show the picture but no sound. Than i connect the audio cable to the tv use 3.5mm j. it only has sound when I use input and select AV3 but...
You probably need a audio cable that runs from the pc audio out to the TV audio in. Radio shack has them so do a lot of hardware store and best buy.
Aug 08, 2009 | LG 42LG30 42 in. LCD HDTV
My sharp cd player is showing error 11. door will
dismantle your cd player and set it up back and it will automatically reset itself. if does not then have a tech repair it as your aduio output is damage or the momory chip needs to be replaced.
Apr 18, 2009 | Sharp Audio Players & Recorders
I am Unable to connect my Aduio cables from the xbox 360 to my TV
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
You should now get pictures & sound.
Dec 28, 2008 | Televison & Video
Polaroid 1911-TLXB 19 in. LCD TV Logo
162 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
