Question about Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5 SHPM15
Breaker for my Jandy stealth tripped and wont stay on, the pump makes a bussing sound, wont move
  • 8,404 Answers
Start/run capacitor may be faulty ...
Posted on Aug 04, 2010
Have a Jandy Stealth pump. In the morning the pump does not prime. I have to remove, replace lid and then turn it on it works as it should.
Sounds like an air leak in the system. If you have a media filter make sure that the back wash line is not leaking or look for leaks in plumbing.
Jan 12, 2017 | Jandy Pool & Spa
I have a old Jandy Stealth it Triped the breaker and pushed the Motor shaft out the back.
Wow, I have never heard of that before! I guess you're going to need a new motor maybe even a whole new pump?
I would doubt that any other piece of equipment created the situation, or even deal electrical supply? But have it checked out, and I believe pump replacement me take care of the problem.
Feb 24, 2015 | Jandy Pool & Spa
Reset Jandy PS6, still flashing red and green
turn off heater if ok then replace ignitor if not keep removing auxs until stops blowing breaker
Apr 02, 2014 | Jandy Aqualink Pda Ps6 Wireless Handheld...
Is there a reset button for a jandy stealth 1.5HP pool pump
it kicks out breaker try turning the motor shaft if still doesnt work need new motor
Jun 27, 2012 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
I have a Jandy stealth series pump and this morning it was not running. The breaker was tripped and when I reset it and turned it on the motor only hums for a few seconds and then the breaker trips...
This sounds like the motor has seized up. You will most likely need to replace at least the motor and maybe the complete pump assembly.
You can take the pump into a local motor shop and see if they can rebuild the motor for you.
US Parts Center
Aug 21, 2011 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
Pump has power at back of motor and I can turn shaft at the back of pump. It is not running.
this motor has a run capacitor, have it tested. search your area for your local pool pump motor repair guy with free testing.. ask him how to remove it, caps can hold a charge and make for a nasty surprise.. THIS IS IF THE MOTOR HUMS OR MAKES A BUZZ NOISE if not, you will need to check the power at THE BACK OF THE MOTOR. no power check, timer, breaker, main breaker ..
Jun 06, 2011 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
Jandy Stealth 2.0 tripping GFI after heavy rain. Been a week since storm.
Very possibly a bad GFI. GFI's are cheap and worth replacing if in question. also might try hooking up directly to another source and see if it trips a breaker
Sep 13, 2010 | Jandy PHP High Head Pump 2 HP Up rated
Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5 SHPM15 Logo
337 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
