Question about Proform Crosswalk 500 Treadmill
Treadmill belt has oil on it
My treadmill belt has oil stains on it
  • Anonymous Mar 30, 2014
    What lube is required for belt.only info I have is use manufacturer oil
    President:
  • Proform Master
  • 832 Answers
Use simple green with a nylon scrubbing brush to the top of the belt ,let dry before using it.
Posted on Jul 19, 2010
When on treadmill there is a "studder"
Check if the running belt is lubricated. You can't run an engine without oil. So, spray a good quality silicone lubricant on the base of the running belt. It is best if you spray on a lint free cloth just enough to make a wet patch. Do it outside so that no spray residue lands on the floor and becomes slippery or lands on the carpet and stains it, then return inside and lift the treadmill running belt and soak or smear the base with the wet patch of the cloth and run for a full minute. Then lift the belt again and give it another swipe on the entire base, then feel the base with your fingers or hand to see if it feels wet and smooth. Run the treadmill for another minute at slow speed, otherwise the liquid can fly and splatter on wall or floor. If it still hasn't solved the problem, then it must be the motor brushes, or it may be set to run slow and fast according to the running settings on the console. Mine does the same thing if it is programmed to do 1 minute slow and one minute a bit faster. Good luck.
Jul 30, 2014 | Proform Crosswalk 395 Treadmill
How can i oiling my kettler pacer belt ?
you dont oil it, you have to put treadmill wax on it, and you just put it under the belt on top of the deck at the front and the back
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Apr 25, 2014 | Kettler treadmill Pacer
For the last couple of days tread belt seemed to be pulling a bit hard and smells a bit of burning when stopped,tonight i switched on bit of a clunk and belt would not turn kicked foot on belt it started...
treadmill belt need always to put a special oil from below, for better sliding. it is a special product you can find it at any service center for treadmill.
Nov 15, 2013 | Exercise & Fitness
Reebok v8.9 treadmill
you must LUBE the deck belt INMEDIATELY, however this indication is the lack of maintenance, probably your have a worn deck, see the diagram attached, and take action.
God bless you
Jul 22, 2012 | Reebok Exercise & Fitness
LUBRICATING OIL FOR TREADMILL MOTOR BELT
Hi, I used to work in a commercial gym and part of the weekly maintenance was to lubricate the belt. Oil will be available from your machine's manufacturer. If it's a home use treadmill frequency will be much less and your manual / manufacturer will be able to advise at what interval, usually in hours. Hope this helps.
Mar 23, 2012 | Exercise & Fitness
How do I oil the belt on a weslo cadence treadmill
http://www.youtube.com/watch?v=f7IZWMMrCM0
observe carefully and pacience.
YOU CAN BUY FROM:
www.treadmilldoctor.com
www.fitnessrepairparts.com
ww.gympart.com
sincerely
Nov 12, 2011 | Exercise & Fitness
How do i lub the belt
Loosen the walk belt by loosening the two adjuster bolts at the rear or the belt a couple of turns. Take your oil and reach your hand under the belt and smear the oil on the smooth board under the belt. After tighten the bolts, start the treadmill and adjust the side to side on the walk belt. The oil will coat the back of the walk belt and you are done!
Hope this was helpful.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Jul 28, 2011 | Exercise & Fitness
My belt is skipping. How do you tighten it and does it need oil
Lubrication will not stop the belt from slipping. If you do lubricate it, do not use oil, use whatever is recommended by the manufacturer, probably silicone.
It is likely your belt is stretched to the point that is needs replacement. You can order a new one through Treadmill World
Oct 05, 2010 | Icon Image 17.5 S Treadmill
Tredmill not moving
That's an embarrasing admission. A treadmill works like a conveyor belt or a car's fan belt. If it is too loose it will slip under load. There will be an ajuster on your treadmill. All you have to do is tighten the belt. Do not overtighten it though. an
Feb 17, 2010 | Cadence Weslo 825 Treadmill Walking Belt
How do i lubricant my treadmill
it is an indicator that the belt needs lubricating. turn the power off, and lift up one side of the belt and spray a small amount of lubricant underneath the belt, onto the running board. repeat this step on the other side. turn the treadmill on and run it for a few minutes to spread the lubricant. the oil light should now go off.
this should be repeated every 5-6 months to keep the board lubricated and to reduce friction between the belt and board and will lengthen the life of your treadmill.
Dec 19, 2009 | Reebok New York Giants Eli Manning Jersey
Proform Crosswalk 500 Treadmill Logo
290 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
