Question about Alesis Sr 16 Stereo Drum Machine
Pads are far quieter than presets so cant play along
    Problem Solver:
  • 8 Answers
Go in and sett the velocity
Posted on Aug 17, 2010
I have a 1990 Alesis SR16 drum machine which has not been switched on for over 10 years. I now wish to use it again but all data including factory presets have been lost. How do I re instate them
How do I reinitialize SR-16?
Power on while holding: "ERASE" and "PLAY".
Evidence: All User songs and patterns will be empty.
Note: Clears memory
Clears the SR-16's User Songs and Patterns, but leaves the Preset Songs and Patterns intact.
Feb 15, 2015 | Alesis Sr 16 Stereo Drum Machine
How do I reinstall preset patterns
According to the Alesis SR16 Frequently Asked Question section: Power On while holding down Erase and Play. http://alesis.com/sr16
Ewi 4000s cutting off
My EWI 4000s started to play by its self making a loud low note and then it stop and now it won't play at all. I Reset to Factory Preset but that didn't help. What do I need to do to get it to play again?
Feb 09, 2014 | Akai Ewi4000s Electronic Wind Instrument
Install PSR E413DRIVER
What driver do you want to install?
Jan 14, 2014 | Yamaha PSR-E413 Portable Keyboard
No sound when trying to play on presets
you just need to replace the internal battery consult manual for location not hard to change flat batt. like in a watch
Nov 24, 2012 | Music
I am not getting any sound with my used Alesis SR-16. I am getting display but just no sound. Help!
Many people have had this problem WHEN they substitued a replacement power adapter.
The CORRECT adapter MUST supply 9 volts AC, NOT DC at 830 ma or more.
The AC is converted inside the SR-16 to both + and - power to run the internal circuits. IF you have connected a 9 v DC adapter, it will NOT have damaged anything, just get the CORRECT adapter and all will be well.
Feb 04, 2011 | Alesis Sr 16 Stereo Drum Machine
I have a Fender Cyber Twin (1st edition, dont have serial number to hand) which I purchased 2nd hand from Ebay. Lately it has had a fault which started off as quite intermittent but has got worse. When...
Check for degradation of C144 a 2200mfd/16volt cap.
This is power source for the 5 volt digital hardware. Check for excess ripple with a scope. The voltage should NOT go below 8 volts. If the voltage dips, the DSP will go nut-case.
Sep 30, 2010 | Music
I bought an Alesis SR-16 drum machine from an online seller advertised as "new". I plugged it in, and it appears that my "new" machine has had all the factory preset patterns erased! Is there a way to...
Hi.
The SR-16 has 50 preset patterns that are built in, I do not think they can be deleted, if there are no patterns the unit may be defective, even if patterns can be reinstalled using an rmidi file or re-flashing the unit.
To reset an Alesis drum machine you have to hold down both Play and Erase buttons while you power on the machine at the same time.
If that does not work, the presets are held into an rmidi file , the Rmidi file is not available for download. I think it can be purchased contacting Alesis or Rmidi.
I quote from Alesis Rmidi page:
"A rMidi Import/Export File named 'Sr16PresetKits.xml' containing the Sr16 Preset Kits has been installed within the folder named 'Sr16' within the directory in which you installed the rMidi FrameWork software. You can Import these Kits into the rMidi Drums Control if you wish. "
Check if you have the file in the folder.
If not the Sr16 will allows you to export your User Drum patterns, but I do not think you can export factory patterns.
Nov 20, 2009 | Alesis Sr 16 Stereo Drum Machine
Alesis Sr 16 Stereo Drum Machine Logo
61 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Will Halftowaite
Are you an Alesis Music Expert? Answer questions, earn points and help others
