Question about Sport & Outdoor - Others
Can I mount the barrel from the 2300T on my 1377C? If yes, what about supporting the front of the barrel since it is 10.1" long? Danny Spurgeon
  • drspurgeon Jul 17, 2010
    It was not what I wanted to hear but, it was a quick answer for sure. Danny Spurgeon
  • 1,284 Answers
Hi, 2300T is only compatible with Crosman 2240, 2250, 2300S.
You can no mount barrel on the 1377C.
Take care
Posted on Jul 17, 2010
    I have seen other 1377c models with a 10" barrel. How is it done and where can I find the proper parts? Any help would be appreciated. Thanks, Danny
When i change to my mossberg 535 rifled barrel can i use the scope mount as open sights
I'm guessing it's a cantilever barrel? Mount is part of the barrel? Sticks back over the receiver? If it's not, then it should already have rifle sights. If it's a cantilever, why not mount a scope as it's designed? You can go 2 or 4 power fixed and you'll have no probs. The prob with using the mount as a sight is there is no front sight....and irons require a front and back to line up the shot. Having a back but no front, you have no sight radius.
Nov 09, 2012 | Mossberg Optics
HAVE A PRONGHORN TASCO MOUNTED ON SAVAGE 22 BOLT. SIGHTS IN OKAY AT 10 YARDS AND THEN IS HIGH AT 25. IS THERE AN ADJUSTMENT INTERNALLY IN SCOPE TO FIX THIS?
No, this is not a scope issue. The scope is raised above the centerline of the barrel, thus at 10 yards, the barrell is actually slightly raised in relation to the centerline of the scope in order to hit your point of aim. Since the front of the barrel is slightly inclined, at 25 yards the bullet is still rising in relation to the scope alignment. Backing up to 50 yards you will begin to see the bullet start to drop back down, at 100 yards it may drop as much as 8-10 inches, and at 200 yards, it may drop as much as 52 inches. This is assuming that you are shooting a standard velocity .22 long rifle cartridge (1050 feet per second or so).
Sep 10, 2010 | Tasco Pronghorn 3-9x50mm 30/30 Riflescope...
Browning shotgun sweet sixteen age and value
In general, a 1950s Sweet Sixteen is a valuable gun. Measure the distance from the trigger to the end of the **** stock to get the "legnth of pull" (LOP). this was 14 1/14 " when it left the factory. If it is shorter, the value will be less.
Without seeing it, although many have been altered which would bring a price $350 - $450 area.
This guide might help if you can determine the condition : OS is 1958.
AUTO-5 SWEET 16
- 16 ga., 2 9/16 in. chamber from 1937-1940, and 2 3/4 in. chamber from 1947-1975, similar configuration to Lightweight, 12 and 20 ga., gold plated trigger, 10 oz. lighter than Standardweight Model 16 ga., 1937-1940 mfg. Sweet Sixteens were available in pre-war Grades I, III, and IV. Mfg. 1937-1975 by F.N.
Grading ...............98% ....95% ....90% ........80% ........70%
Plain Barrel .......$950 ...$825 .......$725...... $625 .......$500
Solid Matte Rib $1,300 .$1,075 ....$950 .......$825 .......$700
Vent. Rib .........$2,100 .$1,650 .....$1,225 ...$1,050 ....$875
Subtract 20% for front safety.
Subtract 20% for 2 9/16 in. chamber.
Jun 24, 2010 | Remington Shotgun Mount 12Ga Lh, B Square...
Hi. how do i remove oil pan of audi a6 2007 2.0 tdi? i have got all bolts off, i can move pan just a litle bit, but it feels like something is still holding it. thanks
YOU HAVE TO SUPPORT ENGINE WITH A ENGINE SUPPORT BRIDGETOOL 10-222A AND ENGINE SLING TOOL 2024A FROM THE TOP.BECAUSE YOU HAVE TO LOOSEN SUBFRAME MOUNTING BOLTS.SUPPORT THE SUBFRAME.REMOVE OR DISCONNECT THE FOLLOWING FRONT BOLTS NUMBER 2 AND 3.BOLT NUMBER 1 BOLT FROM THE SUBFRAME.SLOWLY LOWER THE FRAME.FOR MANUAL TRANSMISSION LOOSEN THE LEFT TRANSAXLE MOUNT NUT UNTIL IT IS ALIGNED WITH THE LOWER EDGE OF THE BOLT APPROX 4 TURNS.IF EQUIPPED WITH AUTOMATIC TRANSMISSION LOOSEN THE REAR BOLT FOR THE LEFT TRANSAXLE MOUNT SEVERAL TURNS THEN REMOVE THE FRONT BOLT FOR THE TRANSAXLE MOUNT.AT THE RIGHT TRANSAXLE MOUNT LOOSEN THE REAR BOLT MOUNT SEVERAL TURNS AND REMOVE THE FRONT BOLT.IF EQUIPPED WITH A MANUAL TRANSAXLE BOTH REAR BOLTS ON THE OIL PAN CAN BE ACESSED THROUGH THE OPENING ON THE FLYWHEEL TURN FLYWHEEL AS NEEDED.THEN REMOVE OIL PAN.
Apr 27, 2010 | 2005 Audi A6
Do they have an internal fuse? thanks. danny
Hi Danny. Yes they have a fuse. Remove platter, remove plastic cover, main fuse is there
Oct 02, 2009 | Technics SL-1210 Turntable
I can't get the front differential out of my 1995 S-10 pickup. It is free from all other parts (axles, u-joint, frame, etc), but I cannot get it to drop. Do I need to lift the engine to create the space...
yes you need to lift the engine a bit to get that front differential out, the best way is to take the center bolts out for the motor mounts (i'm pretty sure its set up that way) if its not, just un-bolt the mounts lift the engine with a jack and a block of wood, make sure the jack is supporting the engine before you unbolt the mounts, lift up untill you can wiggle the differential out, it takes some effort and twisting/turning the diff. to get it to come out,
Jul 02, 2009 | Chevrolet S 10 Cars & Trucks
AC Thermostat wiring
YES U SHOULD MOUNT IT
May 10, 2009 | Heating & Cooling
Crosman 1377 air pistol
the seal must be broken. send it back to whom you bought it from and get an exchange
Oct 22, 2008 | Crosman (4032)
Motor mount
Yes this mount supports a lot of the motor. It also supports the transmission so if you are on a down hill slope the motor will roll forward and cause a lot of pressure on the front mount. Hope this helps.
Aug 10, 2008 | 1999 Pontiac Grand Am GT
Sport & Outdoor - Others Logo
24 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
