Question about Motorola Mobility RAZR V3i Cellular Phone
V3i back light
There is no light on locd and keyboard i changed both the lcd and keyboard flex cable still same problem help me
    Brigadier General:
  • 7,752 Answers
Then the board itself is faulty so you need to try a reflash or replace it.
Posted on Jun 29, 2008
My phone is not turning on, the keyboard lights up
Your lcd is probably ok, it's just a part called the flex cable (a ribbon cable that connects the board to the lcd). If the flex cable gets kinked or torn stuff like this can happen. You can find flex cables on ebay for cheap, but they are kind of tricky to replace in flip phones. There are some sites you can send it in to for repair, and there are sites like ours where you can trade it in for another phone.
www.usedcellphoneshop.com
May 08, 2010 | Samsung SYNC SGH-A707 Cellular Phone
My screen is blank but the phone works
The most common problem is the flex cable that runs from the main board to the LCD. The chrome end cap sometimes breaks causing the flex to break. Moisture damage can also cause this. Is the moisture indicator red?
Nov 13, 2009 | Motorola Mobility RAZR V3i Cellular Phone
My screen just went black
the flex cable that connects the lcd to keyboard/Central unit is faulty
teh responsible chanel of lcd light/brightnes is cut
plz do aret this post as good as u can
Oct 07, 2008 | Acer Aspire 5630 Notebook
I CHANGED THE COVER (6131) AND NOW MY SCREEN GET OUT FROM ORDER
your screen dosnt display anything?I am not quite sure what your asking but ill take a crack at it anyway.you changed the housing and when you put the phone back together the lcd stoped working,if this is the case you either disconnected your lcd or you damaged the flex cable to the lcd,either way you need to open your phone back up just the top part where the lcd is,you should beable to see the flex cable coming from the phone to the lcd if it looks connected disconect and reconnect and try it if this does not work you may need a new flex cable wich means that you may have to get a whole new keypad cause the flex cable usually only disconnects from one side,well good luck
Sep 23, 2008 | Nokia 6131 Cellular Phone
How do I find and change the flex cable (patta) on the RAZR v3i?
try turn ur phone to bootloader moder by press all key together *#power and connect ,,,don't for to charge your phone using ur fren phone.let me if it connect
Jan 12, 2008 | Motorola Mobility RAZR V3i Cellular Phone
V3i Problems
you need to have the flex cable replaced
Dec 30, 2007 | Motorola Mobility RAZR V3i Cellular Phone
NO DISPLAY
i have the v3i and it had the same problem its usely the flex cable that messes up if its opend some times fast the screen gos white if you change the flex that should solve your problem . arubinoff1@yahoo.com cumputer tech
Nov 26, 2007 | Motorola Mobility RAZR V3i Cellular Phone
V3i keypad problem
change flex cable(patta). Include keypad in flex cable so change It and enjoy your phone
Sep 23, 2007 | Motorola Mobility RAZR V3i Cellular Phone
No screen
ok fred you have loose socket in the LCD to main board or the flex ribbon wire thats connect the LCD and the main board! or if not work if you did that! change flex ribbon wire! and or the LCD.
Sep 14, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Display Problem
check the flex ribbon wire that connected to LCD, or maybe you have damage flex ribbon wire you have to replace a New one FLEX. enjoy your phone!!!
Sep 12, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
46 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
