Question about Frigidaire GLTF2940ES Front Load Washer
The machine is not draining and it is not spinning
The machine has water in the basin and when I turn on a cycle it is not spinning
Water sump pump stopped up how do i take the front panel off my front loader to get to it
Posted on Jul 23, 2010
  • Frigidaire Master
  • 909 Answers
Your machine will never spin if there is water in the tub. Remove the pump and clear the obstruction.
Posted on Jul 17, 2010
Hf7 130m. Machine will not go into spin cycle.......will not empty water
water pump is faulty It wount spin when it is full of wate. Put waste pipe down low into a basin to drain it out ...then set spin
Dec 31, 2017 | Washing Machines
I have a lg front loader mod-wd-1025fb washer, i moved the other day & i have just connected the machine up to wash & it fills up with water but wont spin it out & just stands still has a OE...
The OE code appears because the machine is not fully drained after 10 minutes to start the spin cycle. The machine cannot spin with water still not drained due to clogged/kinked drain hose, blocked pump filter, or pump not working. Remove the drain hose from where it is installed and drain the water from the machine into a basin that is enough to hold the water. The drain hose or the pump filter is indeed clogged/blocked if the water does not drain/flow by gravity into the basin.
Check to make sure that the drain hose is clear and not kinked. Open the pump filter cover then remove and clean the filter. Reach in the pump impeller with your finger and turn it to check whether it is stuck or not.
Make sure the pump wire harness is snugly connected and intact. Replace the pump if no issue is found with the drain hose, pump filter, impeller, and the wire harness or after all issues are addressed and the fault code still appears.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Aug 29, 2010 | LG WM-2277HW Front Load Washer
The spin cycle spins very slowly and the clothes come out extremely wet (drippping wet). How do I troubleshoot this problem?
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jul 14, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washer will not pump out water.
drain pump restricted with debree or drain pump bad. if you can hear drain pump humming during drain function then clean out and see what happens
Jun 22, 2009 | Washing Machines
Knocking while spinning
something is loose or broke you need to remove the bottom panel and top panel and see what is hitting may be a strut
Nov 29, 2008 | Whirlpool Washing Machines
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Frigidaire GLTF2940ES Front Load Washer Logo
174 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
