Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
I purchased a house with a mr slim unit and i cannot find any operating instructions for the remote anywhere on the internet. I see below someone had the same issue and the result was a link to the manual. Even that didn't have instructions. Shouldn't this unit have an auto function based on the temperature? I dont want it to run 24 hours a day.
  • Mitsubishi Master
  • 43,501 Answers
You can find anything you need at www.mrslim.com
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
Preset heat stuck at 63. I want to lower the temperature for a vacation
[PDF]PAR-30MAA - Mitsubishi Electric Australia
https://www.mitsubishielectric.com.au/.../IB_PAR-30...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote Controller ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F). Auto. 19 ~ 28 ?C (67 ~ 83 ?F). Fan/Ventilation. Not settable. 13 ...
[PDF]PAR-31MAA - Mitsubishi Electric Australia
www.mitsubishielectric.com.au/.../par-31maa_ib_en.p...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F) .... Preset cooling temperature is higher than preset heating temperature.
My air recycle button just blinks. Also when i turn on the - Fixya
www.fixya.com/support/t26081705-air_recycle_button_just_blinks_also
6 hours ago - Not sure the heat pump is producing enough heat. Nov 04 ... Preset heat stuck at 63. ... Feb 05, 2016 ' Mitsubishi Electric Mr Slim E12C26426.
[PDF]MA Remote Controller Mitsubishi Electric PAR-21MAA ...
planetaklimata.com.ua/.../Mitsubishi_Electric/Mitsubishi_Electric_PAR-2...
Easy Maintenance Function (Only for Mr. SLIM PUHZ series) . .... 4.4.3 Automatic Cooling/Heating Display Setting . ... Monitoring the Operation Data by the remote Controller (for Mr. SLIM) .......... ..............48 . How to .... 63. 4.2 How to set rotation function(back-up function, 2nd stage cut-in function) . ... Preset temperature (. °C. ).
Feb 05, 2016 | Mitsubishi Electric Mr Slim E12C26426...
How do I get MR Slim out of standby mode
if unit is hard wired try turning circuit breaker off and then back on
Feb 14, 2015 | Mitsubishi Electric Mr Slim E12C26426...
New Mr. Slim system just installed. Set to "Heat." Temp setting adjustment on the remote control will not go below 59 degrees. Is that factory setting? Set at 59 it keeps room at 70 degrees,...
I have a related concern. I put the Mr. Slim unit in my garage/workshop and most of the time need it just to keep the pipes from freezing. I'd like to set it at 45 or 50 degrees, but the lowest it allows is 59. I bought this to save energy, but it's forcing me to keep the room warmer that I'd like.
Dec 03, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Programming the remote/system
An online version of the Mr. Slim MXZ30TN manual is posted here on Fixya.com You can access it below:
http://www.fixya.com/support/p92250-mitsubishi_mxz30tn_air_conditioner/manual-21452
I hope this was helpful - good luck!
Jul 09, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
MR.Slim heater - NO HEAT??
make sure you have freon in your system. they act as a heat pump which does A/c as well s heat. without freon you want have cooling or heat.
Jan 17, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Vane control on Mr. Slim Remote
Pls put the vane on the position 2 and then manually turn the vanes to desired position it will not move until the time you turn the power off and you can enjoy the benefits of Mr slim....
Jul 30, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
252 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
