Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
My dishwasher has no power and am hearing A constant highpitched noise
I do have the same problem with my ge dishwasher(model PDW9280J00SS). i just replace the key pad now it's working ok. i got the key pad on line for about $70. part no. WD34X10915
Posted on Jul 22, 2010
Whining noise in my Fridaidare dishwasher
Good Afternoon Bcolcott,
I see that you are hearing a whining noise coming from your Frigidaire dishwasher. I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 20-30 minutes. When power is restored to your dishwasher, if you are still hearing a whining noise, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 19, 2014 | Frigidaire Dishwashers
Went to turn on tv and made high pitch noise like a jet engine. Made this noise a couple times and heard a fan kick on then power went off and red light came on.
Colorwheel eeds replacement most likley it could also be a fan but I would assume its the colorwheel especially if it was real highpitched sort of squealing sound. You can get the colorwheel and free tech assistance from the guys over at www.tvrepairworld.com
Nov 10, 2012 | Mitsubishi WD-65733 65" HDTV
The dishwasher is not filling with water and it makes a contant buzzing noise
Whenthe dishwasher is not filling, it is your water value not opening up on thedishwasher. The constant buzzing noiseyou hear is the value that is sticking not letting the water into thedishwasher.
May 11, 2011 | Electrolux Dishwashers
Left laptop on bed in morning screne would not appear
try reseating the battery but before your return the battery after romving it Press and hold down the power button for 5-10 seconds then return the batt and try turning system on if it boots that will be good but if not try reseating the Hard Drive from the system then try booting again ^_^
Possibly the fan is not spinning in your computer, but if the above still does not let the system boot into windows and nothing is on the screen and u hear high pitched noise most probably the Processor on your system is toast only thing that can cause a no post with a high pitched sound is your processor
Jun 04, 2010 | Compaq Presario 700 470024-192 Notebook
It makes a highpitched noise when turned on like something is caught in the motor
might have some thing in pump like glass /bone/ toothvpick/ plasitc / ect remove bottom cover and ck , if nothing is found replace the water pump seal . they can squeel .. mm
Dec 07, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
Aug 30, 2009 | Frigidaire Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch SHV46C
Replace the fill valve that sound is it trying to open
Mar 12, 2009 | Bosch 24 in. SHV46C13UC Free-Standing...
My whirlpool gold dishwasher GU180 wont start
I had the same problem with the exact same model - put your washer on the lowest wash setting - press and hold the start button for about 3 seconds. THe washer will run for about 5 seconds and then turn off (do not have the heated dry setting on when you do this).
Turn it off (turn the dial), and then try to re-wash.
Dec 25, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Lg 42inch lc7d high pitched noise while off
Sounds like the power supply is making that noise. At this point I would just exchnage the TV.
Mar 03, 2008 | LG 32LX1D 32 in. LCD Television
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
630 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
