Question about Frigidaire Dryers
FDG648GHS0 dryer works but makes loud grinding noise and the clothes get stuck in between the drum & the dryer itself
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
DryerFDG648GHS0 dryer works but makes loud grinding - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Jul 18, 2010
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
My Kenmore dryer model #110.9757 is making a loud noise
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Oct 07, 2014 | Dryers
Loud grinding noises and black streaks on clothes
Your drum rollers may be going bad (grinding noise) which will sometimes cause the drum to drop slightly, creating a gap where the clothes get caught as the drum rotates. (black streaks)
Mar 29, 2014 | Maytag Dryers
Forgot to put the lint trap back into LG Ventless Dryer DLEC855W. Clothing might have gotten stuck inside. Dryer now making grinding noise and drum is moving slowly. Is it time to call a repairman?
The filter simply allows the dryer air to pass through and trap the lint so it will not collect in the exit tube or on the outer vent parts. If anything, the clothes inside the bin will just spin around and be there when you finish. The noise inside the dryer could be from something that was in the pant or shirt pocket and was floating around.
Mar 01, 2014 | LG Electronics DLEC855W Electric Dryer...
When dryer is drying clothes it is making a loud grinding noise. Is this the belt or is the motor going bad? Maytag Centennial
the maytag has a bearing made if a cloth material that is at the front of the drum. when this wears down drum is grating off the metal drum support, hence the grinding sound. the bearing is fairly straight forward to replace.
Jan 31, 2011 | Dryers
My hotpoint dryer has a loud squeaking noise and clothes are getting stuck in the drum above the door leaving brown marks all over the clothes. Why????
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 21, 2010 | Hotpoint TDL15 Electric Dryer
Loud grinding noise and burning rubber smell
Could be damage to drive belt which is made of rubber
Dec 21, 2017 | Kenmore Dryers
Proline tumble dryer TDC6A makes a loud grinding noise.
Howdy: There is a spring loaded belt tenioner that holds the belt in place. They are plastic with steel bearings. They do go out often do to the surround heat in that area. Good luck - Doug
Dec 09, 2009 | Dryers
Drum making intermittent sqeaky noise for 3-4 minutes then stops
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
110 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
