2006 Chevrolet Impala Logo
Anonymous Posted on Jul 17, 2010
AC is leaking water onto the floor on the passenger side, some said the drain line could be plugged?
  • Anonymous Jul 17, 2010
    i dont see the tubes.
Anonymous
Level 3:
  • Master 507 Answers
  • Posted on Jul 17, 2010
Anonymous
Master
Level 3:
Answers
507
Questions
Helped
212175
Points
1493
Yes, the weep drain. Inside the engine compartment, on the firewall, passenger side, half way between top and bottom of firewall. Small rubber tube comes out, then does a 90* turn towards the ground then just stops. You can remove the weep drain and clean it, or use wire to "poke" around and break up the debris. I suggest removing it.
  • 1 more comment
    Well duane, I have seen many vechiles and I can't think of one that didn't have that. I know on luminas they are about 1/4" (inside diamater), cuz that's the one I just did last week. The vechile they are talking about is less then 5 years old. I have never knowen a seal to break within 5 years. I'm willing to bet money that this vechile spends alot of time outside of a garage meaning they park in their driveway or other open area. Probally even in a dusty climate since this problem is happening so soon, cuz most of them I see happen when they are 10 years old or so, but I don't live in a dusty climate. Either way, I suggest to this person take 5 minutes and clean the weep drain, if it doesn't work, you only wasted 5 minutes and there is another solution already.
    as to Whitson Joe, you couldn't see it. On some models, you have to jack the car up on passenger side to see it sometimes. Tube will only be about 4" long or so.
    To Duane Wong, I like the site you use. Detail info at your fingertips. How do I get in there? Cuz vechile I can gain access to is the Jeep-wrangerler-97-02
Duane Wong
Level 3:
  • Chevrolet Master 6,826 Answers
Duane Wong
Chevrolet Master
Level 3:
Answers
6826
Questions
6
Helped
2859425
Points
20233
Yes, the drain is plugged, but you might consider sealing the passenger side area between the firewall and the plastic shield so the floor does not get wet.
Normally water drains down to the ground from the cold evaporator, as if it were a dehumidifier.
Try using a pressure washer to clean the underside and maybe try to direct the stream of water from a pressure washer down the outside vent at the bottom of the windshield.
Also, check for holes in the firewall area where water should come out. It might be kind of hard to see where it comes out. Use the driver's side as a guide on a hot day when the a/c is running.
This problem occurs more often than one might think.
  • 1 more comment
  • Duane Wong
    Duane Wong Jul 17, 2010
    the drain is not a tube, per se, but simply refers to the routing of water inside the area defined by the plastic panels that are horizontal, and the firewall which is vertical, and any louvers that the water happens to travel down after it drips off of the evaporator, which looks like a small radiator.
    that is true for the inside of the panels are as you desribed .. Where as real world experinse, by removing the weep drain and cleaning it is the most COMMON and fastest way to solve this problem, which IS a small rubber tube on the firewall. So, according to you, where does the water flow to from the exaporator? Just sits there? The weep drain gets plugged and water backs up into the system you described. Instead of just a "hole" in the firewall, there is a "small rubber tube" that bends downward towards the ground as I described in my answer. The weep drain is maybe 1/4 hose that gets plugged quite easily. If you don't belive me, look on your own vechile. It's on all of mine, its on all the ones that came through my bay..........
  • Duane Wong
    the drain on my 1988 Oldsmobile Cutlass Calais in the firewall had rubber flappers that got plugged up after sandblasting the vehicle for a paint job. They were actually larger than 1/4" though.
    Grass and sand and dirt got into it, and one could hear sloshing of water when driving it around town, until the drains were cleared.
    I think it varies from model to model and year to year as to where the drain is and how it is configured.
    Also, this person is having a problem with the water actually leaking onto the floor, that's why I suggested they seal the plastic to firewall seam with something.
1 Related Answer
Anonymous
  • 9 Answers
  • Posted on Jul 08, 2010
SOURCE: 92 Chevy S10 Truck...Where is the hose located
Your line should run down the firewall below the condensor. You will probably need to get under the truck to find it. Also I have heard of condensation forming in an air gap between the firewall, which requires you pull the carpet and use silicone sealant to fill the gap. If you need more information there are several S10 specific forums you can check and they will surely get you on the right track.
I drive a 94 mustang and all of a sudden it started leaking under the driver side dash into the floor board and leaking under the car on the passenger side onto the ground and ideas????
AC removes water while cooling at the same time. The drain is partially plugged in the drain pan that is under the evaporator coil. Now it overflows inside your car and onto the ground at the same time.
2helpful
2answers
1999 Buick LeSabre has no cabin filter but leaks water onto passenger floorboard. Any suggestions?
If it has A/C the drain hose could be blocked and if no A/C it could be a leaking windscreen seal.
2helpful
2answers
Why does my 2004 Saturn Ion AC leak water into passenger side floor?
The condensation drain line has either gotten plugged or has fallen off.
The component of an A/C system that makes the air cold is called the evaporator, logically it needs to be in the air-conditioned space. In cars it's nearly always in the dashboard on the passenger side.
Warm air holds more moisture than cold air, so as air is circulated through the evaporator to cool it, the moisture in the air condenses back to liquid, like a mini rain shower in a box. That water, usually called condensate, has to go somewhere so there is a hole in the bottom of the evaporator and a tube to carry it out of the cab, through the firewall, into the engine compartment and onto the ground.
If the tube becomes plugged, condensate will accumulate until it overflows an air vent. If it comes off or cracks, the problem is obvious. It's pretty common for a condensate drain in a car to plug, junk falls into the intake vent that won't fit down the drain.
Clearing it would be simple if getting to it wasn't so involved, check your service manual for details.
1helpful
What is causing water to leak down onto the floorboard of my 2004 Mazda 6 when I have AC on?
this will be condensate from the fins of the ac evaporator in the car and is leaking onto the floor because the drain on the unit is blocked either in the hose or at the bottom of the ac box
Interior leak
Could be connected - - the drain for the ac could be plugged up and the water is dripping into the passenger compartment. The system may be low on freon or have a restriction in the line which could cause it to freeze up. Could be an air flow problem with the cooling fan too.
1helpful
A/c leaking water passenger floor
Usually a sign of a plugged drain tube.
The HVAC box has a tube that drains the water onto the ground.
The tube should be at the bottom of the firewall near the passenger floor.
Car leaks water on the passanger side
Usually a sign the ac drain is plugged up.
Check under the car near the passenger floor for a tube that directs condensation water onto the ground.
3helpful
When i run air condition leaks water on passenger side floor mat
The usual problem when this happens is that the drain line from the AC condenser is plugged causing it to fill up with water which eventually finds a way out and drains onto the passenger side floor. It is fairly easy to fix but requires getting underneath the car on the front passenger side, locating the drain line, normally a flexible hose coming down through the frame roughly below the dashboard. and running something like a coat hanger up through the drain line to remove the blockage. Beware that water will start to run out the hose as the blockage is removed.
Some cars have this problem more frequently than others and you may have to repeat this procedure every year or so. When it starts dripping water on the passenger side again it's overdue.
1helpful
2answers
Water leaking into passenger side floor --seems like something is clogged with my AC lines --temp excellent but water is leaking into passenger side floor board
where your battery sits look inside there maybe some twigs and leaves blooking the drainage holes look all along there i had similar problem on vw passat no arm in looking hope this helps?good luck
2helpful
2answers
Leak onto floor passenger side from neck of ac drain through firewall
it sounds like your heater core is busted. you will have to go under the dash to get to it and replace with a new one
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
