Question about HP LaserJet 3030 All-In-One Printer
HP 8100 wrinkled paper
I have one hp 8100 series printer, its getting jamed or wrinkeled papper
    Problem Solver:
  • 15 Answers
This is the problem of the fuser assembly, pressure roller part must be gone over their and also chance of tefflon sleve might be gone check and replace the part, the printer will work fine
Posted on Apr 29, 2008
Printer show paper jamed without paper in it
There's a small piece of paper on the sensor. 4 in 1 Cleaning Paper for Laser Ink Jet Printers 12 Pack Perfect Data PD... You need paper path cleaning sheets like tho ones here. That should clear the jammed condition.
Aug 12, 2016 | hp deskjet 3600 series
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
Have an exellent used HP 8100 printer in home for private and at-home work use. Replaced paper pickup-up assy less than 1000 pages ago, fuser six months ago. No other obvious problems. Just a couple weeks...
hi warren,
If you can open the printer and detach paper assembly a while then put it back firmly,then also the fuser assembly..see to it that no other particles or foreign materials inside the printer and all were aligned.
Hope it can give you idea.
mastergani
Jan 27, 2011 | HP LaserJet 8100 Printer
Hp 1010 Laserjet wrinkles paper
Typically, what causes wrinkled paper is the fuser assembly in the top rear of the printer. This is not a user replaceable part. I would first check to see if there is anything obstucting the paper path like a torn peice of paper or paperclip etc. You can take it to a printer repair shop to get the fuser replaced for around 100-150 dollars.
Aug 27, 2010 | HP LaserJet 1010 Printer
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
Papper Jamm
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab73
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper is winkeled comming out of my 1320 n printer
window xp.i have same problem about paper coming pcl xl error position: 8.
Oct 17, 2008 | HP LaserJet 1320n Printer
HP 2332 had paper jam- paper removed, but now will not feed paper
Look through the paper path thouroghly. This is usually caused by a peice of papper either blocking a sensor or physicaly jamming the paper path. is it not trying to feed or lamming up and wrinkling the paper?
May 29, 2008 | Office Equipment & Supplies
Papper jam.
There should be a door on the back of your printer, scanner, copier. Open that door and see if you have a paper jame there.
Apr 20, 2008 | Office Equipment & Supplies
Paper completely wrinkled
NONERIGHTNOW, HP makes great laser printers, the commercial LaserJets typically last 8+ years without much more than an occasional maintenance kit to keep them going. The 1000 series printers are quite another story, they are designed for the low end printer market and just can?t take hard usage over time. The typical culprits with paper wrinkling are heat from the fuser or paper problems. -In the paper tab of the printer driver make sure the correct media is selected. This controls how hot the fuser gets which also causes paper curl/wrinkling. -Buy some fresh HP grade paper, improper humidity, coatings and storage can also cause problems. -Try a new HP cartridge. If you still have no success starts a print job and turn off the printer while the paper is feeding. What you want to do is try to freeze the wrinkling process so we can identify what area is causing it. Post this information. Also open the rear, straight through door; also let us know what happens. Let us know how it goes and please don?t forget to rate this posting.
Jan 19, 2007 | HP LaserJet 1300 Printer
HP LaserJet 3030 All-In-One Printer Logo
111 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
