Alpine cda-9815rb I have just purchased the Alpine Alpine cda-9815rb...in car stereo.I want to know how to save and store the sound settings (bass ,treble, balance,fade, and the finer settings for the bass focus...etc)...as after I turn the unit off..It seems to return to default settings.
I solved this problem by calling Alpine Electronics customer services.
Posted on Apr 22, 2008
I am suddenly unable to adjust the base, treble, volume, etc on my Alpine CDA-7940 stereo. Is there a lock or setting for this?
press the mode button, which is the audio knob repeatedly to choose the desired mode and rotate the knob until desired sound is obtained. as you press the mode button, the option will go from these followings: volume, bass, treble, balance, fade
Jan 13, 2015 | Alpine CDA-7940
Need to know how to adjust bass, treble, fade, etc. on Alpine model CDA-7862
Press the MODE knob to choose between bass, treble, balance, or fade.
Turn the MODE knob to change each setting as it is displayed.
Mar 15, 2011 | Car Audio & Video
My cda-9887 does not have a bass/treble setting. Only fade/balance
In the initial stage of the set up your 9887 the stereo is set with an Equalizer (parametric or graphic), Until you use the Imprint set up module to Tune your car you wont get bass / treble controls. Also after Tuning with Imprint you will lose the EQ function, and it will only be B/T.
Nov 02, 2010 | Alpine CDA-9887 CD Player
Can not turn the bass and treble up or down on my alpine CDA-9827
ok i cant see your entire question but to adjust bass and treble on an alpine, you see the knob (the one which u use to turn volume up and down), push it in (itll click) then a screen/textt will come up and say bass or an option once it says bass, turn the knob up or down, then press in again and it will say treble or fader or something else, once again, adjust it and keep pressing in the knob until u reach the volume again. does it work? is this what u wanted?
Apr 11, 2009 | Alpine CDA-9827 CD Player
Adjust
I have an Alpine CDA-9813 and to access bass, treble, fade, and balance, you need to press the volume button. This button is usually rotated to adjust the volume but on mine, if you press it in, first time accesses bass, second press accesses treble, 3rd press accesses balance(left to right), and 4th press accesses fading (forward to rear. Press it a 5th time and it either brings you back to volume or back to the main screen. I think it is volume tho. I would assume that the 9853 would work very similar, if not the same.
Mar 21, 2009 | Alpine CDA-9853 CD Player
With the alpine cda 9851 if you turn the volume past 22 the music goes flat. why?
bass boost effect drops out at 22 if you have an amp turn up the gain or you can set the bass treble etc with bbe off
Feb 18, 2009 | Alpine CDA-9851 CD Player
Finding treble and bass adjustments on my stereo
Here is a manual for the radio. If you go to page 14 it will tell you how to set the EQ.
http://vault.alpine-usa.com/products/documents/OM%20CDA-9835.PDF
Good Luck Please Rate FixYa!
Dec 19, 2008 | Alpine CDA-9835 CD Player
New car, no manual
There is no straigt forward bass and treble adjustment. You must adjust in either the (x-over) or (users EQ) function. It is a bit tedious but performs the bass and treble adjustments at multiple frequencies.
Aug 24, 2008 | Alpine CDA-9833 CD Player
Cannot Set the Treble & Bass
I have an Alpine 9887 you have a different eq than just trebel and bass the only way to get you bass an trebel setings are to install the imprint stoftware now if thats the route you go it tunes your radio to what it thinks it should sound like it's for sound quality not for alot of bass been there done that I have the software but you need to take it to a good alpine dealer to have it installed good luck
Jan 05, 2008 | Alpine CDA-9887 CD Player
322 people viewed this question
 Grubhead
Grubhead
