Question about iLO 3200 32 in. LCD Television
Cant get vcr to work
Help I amnot sure I am hooking up cable box and vcr correctly HD tv works but VCR picture is all messed up
Is your vcr capable of hd output? if not the picture will be a bit distorted(stretched)
Posted on Apr 29, 2008
I have a 70" element TV bought used no remote how do I get the DVD player to work? What channel ??? tv av component etc.....
How do I hook up my tv,dvd player,vcr, and cable box?
askville.amazon.com > Entertainment > Television
Dec 3, 2009 - Recent Questions About: hook tv dvd player vcr cable box · Entertainment > ... Exclusive Coupons To Get 30% Off ... Check the back of your TV to see which type of hookups are available and use the appropriate cables.
Element 46" Class LCD 1080p 60Hz HDTV, ELDFW464 ...
www.walmart.com/ip/Element-46-Class-LCD.../17188433
Walmart
Rating: 4 - ‎190 votes
The Element 46" 1080p HDTV features a brilliant full-HD picture for your viewing ...ShippingPass. H&R Block Tax Software 15, Deluxe + State. $34.70 .... I really cant stand having to use another remote...thats the point of having a .... Just a regular DVD player and it works perfectly fine with the TV. ..... Get to Know Us.
5 Easy Ways to Hook Up a DVD Player (with Pictures)
Jan 10, 2016 | Televison & Video
Restore sound on my Tv, suddenly lost.
  1. Check if the mute button on the cable box/TV/VCR is activated. If so, turn off the mute feature
  2. Verify the volume on the cable box/TV/VCR is not turned all the way down, either by adjusting the volume level on the equipment itself or with the remote control
  3. Check if the TV has an earphone or headphone jack. If so, make sure there are no earphones or headphones plugged into it
  4. Check if the Cable Box/TV/VCR has a SAP/MTS switch (Secondary Audio Program / Multichannel Television Sound). If so, make sure it is set to the proper setting. Consult your TV/VCR manufacturer's user manual for information for your specific TV/VCR. Click here for information on changing this setting on a Cable Box
  5. Check behind ALL TV and equipment (Cable box, TV, VCR, DVD, stereo receivers, etc) and the coax cable at the wall outlet for any loose or damaged connectors
  6. Make sure all equipment and connections are hooked up correctly for the video and audio based on the type of connections being utilized
Mar 10, 2015 | SEG 19 in. TV
How to hook up to a vcr to ikonvert to hd tv
you cant make a video from a vcr change into high definition,you can only hook up to tv,no up convert for vcr
Mar 10, 2015 | Supersonic Ikonvert Sc55 Digital Converter...
I have purchased Samsung 550 - series L5 - I don't seem to be able to hook up the VCR to it to record. I have cable on it and I would like to be enable to record programs. Television ask if I want to...
You don't record from TV, you record from cable so cable needs to be hooked up to input on VCR.
If you don't use cable box you would hook cable to VCR then out of VCR to TV. If you use cable box then you need to connect Video and Audio outputs on cable box to Video and Audio inputs on VCR and switch input of VCR to Line input.
Feb 28, 2011 | Samsung Televison & Video
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
VCR will not record
yes your hook is all correct...but still will not work......unless this is a d-vhs recorder...(and the other way to record hd is dvr)....(note dont throw the standard vcr away) it might and can be use later down road
Jan 15, 2009 | Proscan PSVR73 VHS VCR
My Zenith VCR is not working with the digital converter box
When the VCR is "off" the converter signal should go right through the box, which you say it does. Then, when you turn the VCR "on" the picture disappears. That, so far, how it should be. To get your picture back while the VCR is "on" you must set the VCR to "receive" channel 3, and use your new converter box to change channels...accordianman
Dec 16, 2008 | Televison & Video
Vcr picture problem
clean the heads. check out my tip
Nov 02, 2008 | Orion VR213 VHS VCR
I ahve a hdtv and a vcr how do I connect all three together and a diagram,please, Thanks joe
i dont know how to make a diagram but i will give the best instructions
make sure you follow these instructions so you will take advantage of your tv best possible picture if you hook it up some other way you will not get that great a picture
sat cable
coax from wall to box-use a hdmi cable only no other cable its pure digital connect to the out section on box and in section on tv
dvd
if dvd has hdmi out from dvd to in on tv the same as step one if dvd does not have hdmi then you will use commponent cables red green blue for picture and red and white for audio out from dvd to in on tv
vcr
since you cant record hd on vcr you will just hook it up with yellow red and white (composite cables)out from vcr to in on tv.
if done any other way it may work but not digital and not best picture available to you
Sep 09, 2008 | Televison & Video
Hooking up DVC/VCR to HD cable box/TV
Hi Seve.
Not sure what is meant by 'HD cable box'.
If you mean a DSD (Digital Satellite Decoder), then the built-in firmware prevents recording (of composite video signal).
In our country the SP requires that you buy a dedicated 'Explora' decoder which allows recording.
HD cable technology may have introduced similar anti-piracy measures.
{reminder to me: Google "HD cable TV" :)
Oct 06, 2017 | Televison & Video
iLO 3200 32 in. LCD Television Logo
61 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
