Question about Pentair MINIMAX NT TSI IGNITER
I have a Pentair Minimax Nt Pool and Spa heater. I have just replaced the igniter and module. My problem is the fan and heater will come for approx. 5 minutes and then turn off. Then the digital display states E O 4. Ignition lock out. What does this mean. i had this same problem 1 year ago and I replaced the same parts. what wrong now?
    Top Expert:
  • Pentair Master
  • 9,798 Answers
Check gas supply
Posted on Oct 30, 2017
  • 22 Answers
SOURCE: i have a Pentair MiniMax NT 250,000 btu pool heater that fails to
Two reasons.
1. There is air in the gas line. Power down the heater and allow it to try igniting until lockout. If it locks out, repeat the process. Most lines will clear within 4-5 attempts to ignite.
2. A plugged burner orifice. Run a small pipe cleaner in the brass fittings on the burner tray. They may have small webs in them restricting gas flow.
If the unit is a Standard (STD on the plate inside) it has a flame sensor that may also be bad. That sensor is on the end of the single wire that is cloase to the ignitor wire near the burners. Also check for a losse ground wire on the heater.
Posted on Dec 21, 2008
john224
  • 1378 Answers
SOURCE: new ignitor..still won't light
Clean out the pilot assemby or replace it. It is probably blocked by rust and/or spiders and is not letting enough gas (if any) through.
Posted on Jun 23, 2009
  • 128 Answers
SOURCE: Pentair minimax nt just replaced ingnitor module
This means the air switch is bad.
Posted on Aug 23, 2009
  • 246 Answers
SOURCE: Minimax 250 Cycling on and off after reaching 20 degrees
change the assembly valve
Posted on Oct 13, 2009
  • 990 Answers
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Posted on Dec 12, 2009
How do i install an igniter in minimax
Pentair 472604 Igniter Replacement MiniMax NT STD Pool and Spa Heater
The ignitor is simple to replace, It is either a spark ignitor or a Hot surface ignitor. The above link will take you to a picture of the Hot surface ignitor, it is normal held onto the bottom of the burner tray, at right about the middle, by 1 or 2 sheet metal screws.
If a Spark style ignitor/electrode, then the bottom link is the one want to look at. Again, held in place the same way as above description.
Pentair 471090 Ignitor Electrode Replacement MiniMax 75 100 Pool and Spa...
Good Luck
Jun 04, 2014 | Pentair Minimax NT Heater
I have a Pentair MiniMax NT heater. The fan does
if voltage to fan replace capacitor if no voltage check safety circuit
Aug 16, 2017 | Pentair Minimax NT Heater
Pentair MiniMax NT pool heater not working
check breaker maybe popped check ignitor
Sep 29, 2017 | Pentair Minimax NT Heater
My new ignition module doesn't have TH, F1, F2
no, the replacement ignition module should be an exact replacement for the old one.
Nov 09, 2009 | Pentair MINIMAX NT TSI IGNITER
Pentair MINIMAX NT TSI IGNITER Logo
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
