Question about Kenmore Refrigerators
Kenmore cold spot model 106 66862790 mf date08/97
Kenmore cold spot model 106 66862790 mf date08/97 top freezer quit but fan runs all the time does anybody know where the defrost timer is
  • 33 Answers
SOURCE: Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Posted on Jan 01, 2008
  • 236 Answers
SOURCE: Red light blinking inside freezer
The light may be telling you that the temperature is not cold enough to operate the icemaker.
You may have a bad defrost timer, heater or thermostat. If you have an ice bucket then it may ot be seated properly.
Stargazer
Posted on Mar 16, 2008
22yooper
  • 828 Answers
SOURCE: Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Posted on Jun 01, 2008
  • 62 Answers
SOURCE: Kenmore Elite Bottom Freezer Mod. #795 75544401
The unit was built bt LG. It is a computer controled unit and the timer is built into the main control board on back of the unit. However, the most likely cause of the broblem is the defrost terminator located on the evap on the upper right hand corner. Also, try unpugging the unit it will reset the computer board. You will also have to defrost the unit.
Posted on Aug 30, 2008
  • 531 Answers
SOURCE: defrost timer location on Kenmore model 106.56542400
carry control board part#2149705
Posted on Apr 06, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Kenmore freezer quit freezing, no longer getting cold
for a chest freezer if there is a small amount of frost around the top but not down about 2/3rds of the way it's low on gas.
upright if only part of the shelves are frosted then low on gas.
upright self defrost. check for frost build up or fan not running.
Jun 27, 2010 | Kenmore Refrigerators
I have a side by side Kenmore that is in our basement. Does not get too cold by any means, maybe 65 degrees year round ambient tempearture in teh storage room it sits in. 2 months ago we put a quarter of...
yes it sounds like your only problem is that the evaporator fan is not operating so open the freezer door and see if you hear it. if you do not hear a fan running in the freezer make sure that the other fan in the back and the compressor is running. just replace the evaporator fan in the freezer and that should do it
Apr 01, 2010 | Kenmore 54662 / 54664 / 54669 Side by Side...
Its not getting cold
MAKE SURE THE FANS ARE RUNNING FREEZER AND COMPRESSOR, THEN CHECK THE BACK WALL OF THE FREEZER IF ITS FROSTED UP YOU HAVE A DEFROST ISSUE. IF THE COMPRESSOR AND FANS ARE WORKING AND NO FROST IN THE FREEZER THATS NOT A GOOD THING..
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | Kenmore 74852 / 74854 / 74859 Top Freezer...
Freezer ok refrigerator not cold we changed the overload relay model no. 59673503201 kenmore elite
feel door seal after door has been kept closed for a quite a time.If it feels warm at any one spot door seal needs replaced.adrian;;;;
Nov 10, 2009 | Kenmore Freezers
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The motor on the Kenmore refrigerator is running continuously. How do I stop it? I just cleaned out the dust from the coils underneath and replaced the kick-plate at the bottom
Hi: I've dealt with Kenmore for 30 years. Unfortunately the new model numbers don't reveal the age. I must assume it's a newer model. I'm not disputing what you said about it running all the time, but please read on. Oddly enough the new energy efficient referigators run 70 to 80% of the time. They use a smaller compressor without the big amperage start-up. The best I can describe them is that they freewheel alot. The 106......of your model number means it was built by Whirlpool. A very quite and energy efficent refrigerator. If your power bill is high get a meter from your power company, most have them. Just to double check the power consumption. Good luck Jeff
May 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
Kenmore refrigerator model 253 not getting cold
i have the same problem: botttom of refrigerator does not cool.
freezer working ok.
Sep 30, 2008 | Frigidaire FRT17G4B Top Freezer...
Refrigerators Logo
172 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
