Question about Sonia GENOA COLLECTION TOILET ROLL HOLDER - 107698 - Chrome
The holder has fallen off the wall. There appears to be two screws, one that fits into the back of the centre of the wall plate and a small one that fits into the side of the wall plate. I don't think anything is missing but I can't get it to stay on the wall. Can you help me,please? Alicia
    Scholar:
  • 67 Answers
Hello Alicia
Most often the wall plate will screw to the wall and then there is a set screw (usually an allen key) to tighten the fixture onto the wall plate. If it is the wall plate that won't stay on the wall then your screw holes are probably stripped. An easy way to fix this is to fill the hole with a wood glue filler available at your local hardware store. Use toothpicks to jam the filler into the hole. You can also use white wood glue and jam glue and toothpicks into the hole. Let it dry overnight and the next day you will be able to screw the plate back onto the wall. If the fixture is falling off the wall plate then the set screw is not being tightened hard enough against the plate to hold it onto the wall. Good luck with the repair.
Posted on Jul 19, 2010
How do I replace carbon brushes in vax6131
Bend back the three tabs and cut off the contact wire as close to the top tab as possible. You can then pull the brush (or what is left of it) out. The new brushes have a brass plate the same size as the brush opening. The connection wire that you cut away on the original brush is attached to this plate so you don't have to solder the connection. Push the new brush into the holder (you might have to file the carbon slightly to get it in). Then you have to compress the spring so that it all fits into the brush holder (this is difficult) once this is in keep the sping compressed with a small screw driver or other small tool, and bend the three tabs back over the brass plate to hold it in place. Give that a try and let me know how that works for ya.
Jun 11, 2011 | Vacuums
Moen dn8408ch fell off the wall post. How do I reattach?
There should be a set screw on the bottom. Position the holder on the mounting plate and re tighten screw. It takes a pretty small flat head screwdriver. Here is the pdf format manual for this holder.
http://www.moen.com/shared/pdf/dn8408sp.pdf
May 15, 2011 | Moen DN8408CH Preston Toilet Paper Holder,...
I believe I have a Moen single post tissue holder. It has loosened from the wall. I am unsure how to disassemble it to tighten it back to the wall. can anyone dierct me to the appropriate instructions?
Normally these have a small grub-screw on the underside (close in to the wall) that hold it tight onto the wall fixing bracket. Slacken off the grub- screw with small screwdriver or allen-key as appropriate then lift off the fitting.
Feb 23, 2011 | Home
I have a jammed Honda 600 Transalp centre stand. Can anyone help ?
I have just fitted a main stand to my Transalp 650 , if by jammed you mean rusted i think the only way would to remove it ! if thats the case you would have to remove the springs take out the split pin and tap the main bar out , grease well and fit back using two screewdrivers , use a larg phillips and a small flat screwdriver, lever the large spring down to the spring holder with the phillips and then then flip it onto the spring holder using the small flat screwdriver, then i used some strong cord to pull the small spring down onto the same spring hook ( holder)
Nov 15, 2009 | 2000 Honda XL 650 V Transalp
Brother sewing machine model XL-6562.needle holder came off rod.n
The needle holder has a screw right above the screw that holds the needle in place. It really doesn't look like a screw because it does not appear to have a slot for a screwdriver. However, with a small flat head screw driver you can tighten it up. There is also a curverd wire that must be inserted into a slot at the bottom of the holder. The screw tightens against the wire that tightens against the post. (It's a curved wire that curves around the front part).
Jun 24, 2009 | Brother XL-5130 Mechanical Sewing Machine
How to remove the mounting flange from a circular, one-arm toilet paper holder, so it can be re-mounted? there is no set screw to release it-- the flange has two screw holes on either side of a center...
you will need a vary small flat screw drive and at the bottom of the holder the is a small hole insert screw driver and un screw, it has a small screw that holds to the plate on the wall
May 05, 2009 | YORKSHIRE 5308 - Yorkshire Paper Holder -...
I wish to replace the battery myself, how do I do this?
Polar tells its customers to send watches to them for battery replacement. But the Polar Fitwatch is too old (may have been introduced in 1997?), and they no longer support it. So the only solution is to replace the battery some other way.
For most people I'd say go to a store that sells watches, they'll replace the battery for a fee.
For those who are handy, you can replace it yourself. I did mine yesterday.
The battery is a common type - CR 2032.
You'll need a small screwdriver, philips type, I think. Maybe around 00, or thereabouts. And you need tweezers, preferably with a rubberized grip.
There are four screws holding the back plate. Remove three, and loosen the fourth. Slide the back plate aside.
I unscrewed the screws, then used the tweezers to take them out. They're a bit small for your fingers to get a good grip on them.
The battery is held by a plastic holder that's held by 4 screws. These are (to my eyes) slightly smaller than the ones holding the back plate, so please keep those separate - and keep track of all the screws.
Remove the plastic holder, and make sure you keep track of the spring that's between the holder and the back plate. It'll likely fall out when you turn the holder over.
The holder keeps the battery with a small prong, but it's easy to slide out the battery. Replace the battery, getting the orientation right, making sure you don't touch either side with your bare fingers. This part is easier than it sounds.
Replace the holder, and of course you noted beforehand what the orientation was, so you get it in the same position.
Use the tweezers to drop each screw into its hole, then screw it in.
By this time, the watch will probably start beeping when you tighten one of the screws, because you depress one of the buttons on the front.
Put the spring back in its hole, then slide the backplate back into place, and drop the screws in place with tweezers and tighten one by one.
You should be able to find a manual (which doesn't cover battery replacement procedure) by searching for polar fitwatch manual.
Apr 28, 2009 | Watches
Fitting a door to Kenwood dishwasher KDW243A
Hello, Found this while looking for the answer myself. The vanity door fell off last night onto my foot and so needs must as it really hurt!
Anyway there are 2 top pillars that fit into the upper appliance door. Then there are two plates that need to set to finished height.
To fit. First insert the top pillars into the large openings. Now open the dishwasher door a bit, took two of us to get this right, and push the vanity door as high up as you can. Next slide the door back down and gently push the bottom plates into the recesses on the appliance door.
Job done! Well almost. When you have got this far open the dishwasher door completely. You will see a plastic white cover caps on either side of the door. Remove these and drop a screw into the hole.. Make sure you measure the screw against the vanity door so that the screw does not go all the way through!! Now screw the appliance door to the vanity door.. Now the job is now complete!
Hope this helps!
Jan 01, 2009 | Danby DPAC120061 Portable Air Conditioner
Spring came off freezer door on chefmate RS-06DR. Don't know to attache spring to freezer and door
I had that same issue - a little tricky to describe the fix, but here goes (very non-technical terms used here):
1) take the freezer door off if it hasn't already fallen off
2) unscrew the single screw that holds the plate (that the freezer door attaches to), onto the interior side wall of the fridge.
3) gentle ease the plate away from the fridge wall. It has some plugs that expand to keep in snug to the wall. Now that the plate is off you can work more easily with the spring and door.
4) The spring has 3 parts, the hockey stick end, the spring tube in the middle, and the u-shaped end. The door has a longer top guide (male) and a lower, shorter guide (male), and a tiny hole about 1/2 inch from the top guide. The plate has a bottom bracket (female), a top hole (female), and the top ledge that contains the top hole.
5) insert the hockey stick end of the spring into the tiny hole of the door while fitting the spring tube over the doors top male guide.
6) (this is the tricky part) - force the u-shaped end of the spring so it straddles the top ledge of the plate so that one part of the wire is above the plate and one part of the wire in below the plate.
7) while doing #6, the top male guide of the door should be inserted into the top female hole of the plate
8) snap the lower male guide of the door onto the female guide of the plate
9) you now have the door assembly intact. gently push the plugs of the plate back into the side of the fridge and screw the screw in.
It took me awhile to figure out, and the above instructions are from memory so if I got it a little wrong, you'll hopefully be able to figure it out. The keys were understanding where the spring fit and taking the plate off the fridge. Good luck.
Apr 28, 2008 | Refrigerators
Sonia GENOA COLLECTION TOILET ROLL HOLDER - 107698 - Chrome Logo
328 people viewed this question
Top Sonia Home Experts
john h
Tom Chichester
Are you a Sonia Home Expert? Answer questions, earn points and help others
