Question about ASUS Computers & Internet
This is my first PC build...I am using a P6T ASUS MB I have installed and completed the BIOS now would I now install the ASUS software CD that came with the MB or my Windows7 OS? Does it matter which is loaded first?
    Problem Solver:
  • 14 Answers
Yes, you need to load Windows, load motherboard drivers, load 3rd party software/hardware and drivers, Windows update if it has not already been told to auto update.
If you have a seperate graphics card, download latest drivers, dont use the windows drivers, or the driver disc that came with the card, they will be out of date
Posted on Jul 17, 2010
Cant find p35-153-11z9 driver
Tere isn't a separate driver for the Realtek 8201CL 10/100 Mbps Ethernet Controller. The driver is part of the chipset software & should have been installed when you installed the Asus motherboard support CD software. (Asus K8U-X).
Double check your bios settings. Check that the onboard LAN controller is set to Enabled. See page 2-19 in your Asus manual.
Link to Asus; http://support.asus.com/download/download_item.aspx?product=1&model=K8U-X
Link for manual; http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8U-X/e2010_k8u-x.pdf
Realtek wants people to use Driver Detective to help in finding drivers from RealTek, see the link posted; http://www.driversupdated.com/exact/realtek.php
(I do not know what the these mean from your post, P35-153-11z9)
If your LAN is set to enabled in the bios, try reinstalling your Asus CD software, (Chipset drivers). If the drivers still fail to install it is possible the LAN controller is defective.
Sep 02, 2011 | ASUS K8U-X Motherboard
I can't find the p6t deluxe v2 motherboard manual, how can i get it?
You can download it from Asus. Open the link provided;
http://www.asus.com/Search.aspx?SearchKey=P6T%20Deluxe%20V2
You'll need Adobe reader installed to view the manual. You can also buy the manual from Asus through Asus Estore link; http://estore.asus.com/shop/item.asp?itemid=5285
Cheers'
Mike
Apr 03, 2010 | ASUS P6T Deluxe V2, LGA1366, Triple...
I am running a core two duo [2.4 ghz] with 2 gigs of ram [two one gig sticks] and was running dual 8800 gts vid cards [now running one] power suply is a 600 w Antec..MB is a p5n32-e Sli Asus, Ok heres the...
CK ALL YOUR DVD CABLES AND BE SURE THEY ARE IN TIGHT, ALSO CK THE MB PLUGS ARE IN TIGHT AND POWER PLUG IN IS DVD PLAYER CORRECTLY. DID YOU INSTALL THE SOFTWARE THAT CAME WITH DVD PLAYER??? IF SO, DELETE IT AND REINSTALL. SOMETIMES THAT IS ALL IT TAKES.
Nov 20, 2009 | ASUS AI Lifestyle P5N32-E SLI...
I want to know all specification about the ASUS P6T SE motherboard also what kind of mother board is best
Open the link provided below. Asus Specifications P6T SE;
http://www.asus.com/product.aspx?P_ID=t4yhK6y9W9o7iQ9E&content=specifications
The best MB of the Asus P6T series is the P6T Deluxe V2;
http://www.asus.com/product.aspx?P_ID=iRlP8RG9han6saZx&content=specifications
If you want either MB and you want it to run ultra fast buy a 10,000RPM SATA 300 hard disk drive. Read this post by Jeff;
http://www.codinghorror.com/blog/archives/001304.html
I like the three year warranty that Asus provides. Most MB manufactures only warrant their boards for 1 year.
I hope this helps you to decide
Cheers!
Mike
Oct 15, 2009 | ASUS Computers & Internet
Hard drive not detected
make sure your settings are correct on the hard drive. try setting to cable select. if that does'nt work try master pos. reboot and should work.
Apr 14, 2009 | Computers & Internet
Want to install xp by caldera dr dos
The problem is hard enough for beginners . First :
1.DR DOS is used by ASUS . DR DOS isn't MS-DOS (Microsoft), just 99% compatible with it . You have access with it on whole HDD+cd/dvd but , because drdos will enable only 8MB RAM you can't install winnt.exe from i386 . There are at least 2 solutions :
a. if drdos is enable because u reseted BIOS try to change bios according to a better result (avoiding Caldera) and start a nice windows installation;
b. u may use another desktop/laptop until the first restart (in installation) ; u must try to use a computer with ~motherboard for best results.
Don't forget that DR DOS Caldera is almost every time used on ASUS MBs with all on board and you must have a PS2 keyboard/mouse to use any kind of DOS . I read sometimes that DRDOS is a soft used by Microsoft which it's wrong - there isn't any link between drdos and any windows system , genuine or not .
DRDOS problem might appear because it's a soft put on ASUS MB cd driver and , sometime, might be on a BIOS ROM .When u will boot with the MB cd driver in this kind of problem might occur .
Other way Caldera may appear is when u have a windows cd made careless with NERO and caldera will appear no matter the MB .
Mar 24, 2009 | Microsoft Windows XP Professional SP2
Usb keyboard no longer recognised during boot process
Restore your PC before the BIOS update. BIOS updates are not required until & unless you face problems while running a software and it will prompt you for BIOS update. Do this update if its vital othewise do not intergere in the BIOS. I faced the same problem and after unistalling all drivers and again reload the original driver from MB VD slved it. Another thing in BIOS is USB setting at high-spped & full-speed. Try changing those settings and retry. Mine worked!...sodeep
Mar 22, 2009 | ASUS Computers & Internet
P35-153-11z9 mother board need network adapter driver ?
Hi Paul, there isn't a separate driver for the Realtek 8201CL 10/100 Mbps Ethernet Controller. The driver is part of the chipset software & should have been installed when you installed the Asus motherboard support CD software. (Asus K8U-X).
Thanks for using FixYa Paul!
Need more help? Post here.
Mike
Mar 14, 2009 | ASUS K8U-X Motherboard
Can't install a driver
i've lost my driver cd for my asus wl -167g, can i download it for free?
Apr 03, 2008 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
