Question about Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC
Amvo.exe application error
Hi there i would just like to know why this message keeps popping up when i start or close my xp with reference to some memory....
  • Anonymous Jun 10, 2008
    amvo.exe-application error "0x10014112"
  • edwinB Jun 18, 2008
    amvo.exe error
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Though you didn't include the actual message, memory issues can be from not having enough RAM, having physical RAM that is defective (run a memory check), or running too many processes for your system's capabilities. Take a look at the Task Manager to verify services are not overloading your PC capacity - you may need to add RAM. Thanks for rating FixYa!
Posted on Apr 21, 2008
Updater has stopped working ... error message pop up
turn it off in startup .
clik your start run
type msconfig
look in top right for startups
unchek
SoftwareUpdater.exe apply close restart system
Aug 03, 2014 | Microsoft Windows 7 Home Premium 64BIT...
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
May 14, 2010 | Yahoo Messenger
Wf2k.exe - unable to locate component
Download tis file from google.com then paste in C://windows/system32 then try.
Dec 03, 2009 | Computers & Internet
Pc hangs during shut down
As far as Free Antivirus is concerned, you can download Avira from http://www.free-av.com/ It has the highest detection rates & also extremely light on the system.
May 06, 2009 | Computers & Internet
Dll driving me nuts
Hello EricS777
The part where it looks like your xp stuff and vista stuff switch drives is normal. Only the Operating System associates the hard drives by letters this does not mean your hard drive files are switching. This happens because D: drive is Root of Vista OS and Root of any OS in windows gets the C: drive lettering.
dwwin.exe, drwtsn.exe dll is the "Microsoft Application Error Reporting" tool.
I think the message means that something is crashing during system shutdown. When the crash occurs the OS launches dwwin.exe to report the error, however the windows operating system is shutting down and so the application can't launch make the system lockup or hang.
Your problem isn't with dwwin.exe, you need to find out what is actually crashing at shutdown.
If you can`t find out what it is, try going to Administrative Tools/Services and disable the “Error Reporting Service”. You don`t want that running anyway.
Also right click My Computer/Properties/Advanced/Error Reporting
Put a check at both
Disable Error Reporting
But notify me when critical errors occur
Then, if that was the cause and the message stops, we`ll have to try to identify the cause.
May 05, 2009 | Acer Computers & Internet
The ntvdm cpu has encountered an illegal instruction
I took this from another web site:
Michael Chiew said:
What did you do before this happened? What were your last deeds on the machine before the pop-up appeared?
I think what you're referring to is NTVDM CPU, not NTDVM CPU. Am I correct?
What do you know about 16-bit and 32-bit applications? Well, 16-bit applications are those that must work within the DOS (Disk Operating System) environment, a real-mode arena. NTVDM stands for NT Virtual Dos Machine.
In Windows XP, as in Windows 2000, or Windows 98, there are 16-bit and 32-bit environments (real mode and protected mode respectively).
Windows XP can only operate in 32-bit mode. All 16-bit applications must work within its own theatre of operation, typically, the first MB of physical memory (ram). Conversely, 32-bit applications must function above the first MB memory line. If either of these applications happens to slip into "alien" territory, you get an error message like "something" has encounter an illegal instruction. In other words, the wayward application is trying to slip by the immigration checkpoint.
In your case, updatemgr.exe (I suspect updatemgr.exe is a 32-bit application) has in all likelihood wondered into the 16-bit arena. Hence, NTVDM CPU issues that warning.
Why do you continue to get the message. It's because updatemgr.exe incessantly misbehaves itself on start-up, always trying to load itself into a particular memory address where it is not welcome. Why the persistence? Updatemgr.exe has gone bonkers. It is either corrupted or damaged.
On the other hand, one cannot discount the possibility that NTVDM (NTVDM.EXE) is corrupted or damaged. So your problem lies with either updatemgr.exe or NTVDM.EXE, or both.
There are 2 things you could do.
First, establish who owns updatemgr.exe, Microsoft or some third-party owner. Second, rename updatemgr.exe and see whether the message goes away.
To establish ownership (and the function of updatemgr.exe), do a search for the file.
Click START, select FIND. In the FIND dialog box, type: updatemgr.exe. See the directory in which the file has lodged. In Windows Explorer, get to the file, right-click on it, select PROPERTIES. Who owns it? Is there an indication of its function.
Next, rename the file. Right-click it, select RENAME and rename it to, say, updatemgr.old. RESTART your computer. Do you still get the error message. Not likely.
To clean things up a bit, perhaps it is a good idea for you to replace the current NTVDM.EXE with a new copy. Find out where NTVDM.EXE is. Then, click START, select RUN. Type in the RUN dialog box SFC to run the System File Checker. Insert your OS CD, follow the prompts, extract a copy of NTVDM.EXE and send it to its place of residence. Of course, you should also replace a copy of updatemgr.exe.
That should eliminate your problem for good.
Dec 25, 2008 | Microsoft Windows XP Home Edition
take yorur all imaptant data on dvd/ cd your pc infacted by virous u need to do format your all partiton for remove it insatll macfee antivious to protect your pc for futer there is no other way to remove it
thnx using fixya
Jul 10, 2008 | Microsoft Windows Xp Home Edition Sp2...
Looking around the internet it looks like the file is a virus, thus causing the issues you are experiencing. Download a good virus/spyware protection program like spysweeper to clean it and keep it from happening again.
Click HERE
Jun 06, 2008 | Dell Microsoft Windows XP Home Edition
Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC Logo
125 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
