Question about Ryobi Cultivator
Starter rope broke, how do I know what to order?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 12 Answers
U really don't need to order anything.
Go to the hardware store and find some braded nylon line the same size as the old rope. Take a look around on this site, someone will tell u how to fix it.
Posted on Jul 27, 2010
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
Tip
How to fix a recoil rope starter on lawn and garden equipment.
This tip is to help you if your power equipment starter rope broke and needs to be replaced. <br /> Step One: Prepare the equipment to be worked on by disconnecting the spark plug wire from the spark plug. This will prevent accidental startups while working on the engine. <br /> Make sure safety systems are in place. If this is a ride on unit make sure the brake is set and the battery is disconnected. <br /> Step Two: Remove the Starter housing or blower housing. The starter itself will have at least three fastening points and may vary in shape depending on the machine. It is not recommended to remove any rivets if you come across them. Most machines with rivets are part of a larger housing that needs to be removed. <br /> Step Three: Remove the leftover rope and inspect the starter spring. Once off of the machine you can remove any old rope and test the spring. the spring test is to spin or charge the spring as if the rope was being pulled out. As long as tension builds up in the spring you are ready to put a new rope in. If the spring does not build tension order a new spring from a dealer like www.arcolawn.com <br /> Step Four: Charge the spring and install the rope. Charge the spring as mentioned above by rotating it as if the rope was being pulled. Once tight back the spring off one turn and put the rope into the starter through the housing and into the pulley. Tie a knot on either end ot the rope and then slowly let the rope into the starter (make sure the grip is between the two knots). <br /> Step Five: Reinstall the starter housing on the machine and test. <br /> I hope this helps. Joe <img src="barterjoe.png" /><br />
on Feb 21, 2011 | Garden
The pull cord on my pressurewasher just broke How do I fix it?
Usually you have to take the shroud that contains the recoil starter assembly off to get to it. You may have to take it apart to fix the rope. If it broke on the end nearest the starter, you probably have enough rope left to reuse it. Usually they break right at the starter, due the the constant bending and rubbing. Pay attention to how it comes apart, and make sure to rewind your spring before putting the rope back on the pulley, otherwise it will not wind back up.
Apr 24, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Starter pull rope broke. how do i replace?
Should be 3-4 bolts right on top of the pull starterhousing, take them off to replace string
Nov 09, 2009 | Garden
Starter rope pulled out and wont retract on craftsman trimmer/edger 32cc convertible incredi-pull
remove the starter cover and try to wind the starter rope manuly. the rope may have to be replaced if worn or broke..
Oct 22, 2009 | Craftsman Garden
The starter rope on my 14PZ push mower broke. How
The starter rope on my Masport push mower broke. How do I replace the rope and/or starter?
Sep 27, 2009 | Garden
The rope broke on my lawn mower and I am trying to rewind the spring, but was advised to buy a complete starter assembly, I need to know how much one is and where can I get one. I bought my lawn mower from...
If your rope broke, there was no reason to take the spring out. The rope can be replaced just by taking the rewind housing off, turning pulley to get rest of old rope out, wind the pulley (and spring) the direction the rope would be pull it when starting. Then , when it's wound tight, back off to align the holes in pulley and cover. Hold it there, stick about an 8' piece of rope from the outside through the pulley and tie a knot. Hold the rope and let the spring pull the rope back into the starter. an tie handle back. Take your housing, and spring to a shop. They can re-install the spring and put on a rope a heck of a lot cheaper that buying that whole assembly.
Jun 16, 2009 | Mtd 22" Yard Machine Push Mower
Starter rope broke on yard machine
Take the top off. Remove broken rope. Rewind spring until tight, then unwind one turn. Insert and knot new rope.
Jun 07, 2009 | Mtd 22" Yard Machine Push Mower
Starter rope broke
Unless you know how or have the patience of Jobe save yourself a lot of grief and take it in to a lawnmower repair guy.
Mar 24, 2009 | Garden
Pull starter rpoe broke off
You have to wind it up good and tight Prior to Reinstalling. Let me know.
Jan 15, 2009 | Mtd 22" Yard Machine Push Mower
Ryobi Cultivator Logo
78 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
