Question about Gateway (4000484) Motherboard
I have a Gateway computer running Win98 that prompts me for a password at startup. It didn't use to do this, so I don't know what password it is asking for. Never used one! It is doing this after a power outage and had been left off for some time. Any Ideas? I have tried the ESC key with no results. After entering 3 attempts, it gives me a "system disabled" prompt and will do nothing until it is shut down and restarted.
    Brigadier General:
  • 10,406 Answers
Somehow, the motherboard thinks that a "start-up" password is required.
If you have a desktop computer, turn the computer off, open the case, and look on the motherboard. Look for three pins (labelled 1, 2, and 3), and look for a small "jumper" that is connecting pin 1 to pin 2. Move the jumper to connect pin 2 to pin 3. Wait 5 seconds.
Move the jumper back to connect pin 1 to pin 2.
Turn the computer on -- the "BIOS-password" will have been removed.
Posted on Jul 18, 2010
How to find out password for startup on gateway sx2110g desktop computer
It sounds like a Bios or Hard Drive password has been set. This does not happen by accident, start asking everybody with access to the computer.
Dec 31, 2016 | Gateway Computers & Internet
Run time error 75 path file access error
You should try to clean boot the system to see if the problem clears up.
Follow the steps below to place your computer in "clean boot"
  • Click the Start on your Desktop
  • Type msconfig in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  • On the General tab, click Selective Startup.
  • Under Selective Startup, click to clear the Load Startup Items check box.
  • Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  • Click OK.
When you are prompted, click Restart.
When the desktop loads, test again and see if you still receive the error.
If this does resolve the issue
then to set your computer back, to boot normal:
  • Click the Start orb on your Desktop
  • In the Start Search box. Type msconfig, and then press ENTER.
Click the General tab.
  • Click Normal Startup - load all device drivers and services, and then click OK.
  • When you are prompted, click Restart to restart the computer.
Nov 27, 2013 | Retail Supplies
Reset cisco aironet 350 adapter
Try Putty and a 9pin male to RJ45 RS232 serial console cable.
the instructions are in the link provided here:
http://wirelesslanprofessionals.com/wp-content/uploads/2010/01/Password-Recovery-on-Cisco-APs.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Jun 30, 2017 | Computers & Internet
Open laptop and the screen wont go on
try removing the battery from th back.wait for like 5 minutes then restart the computer.
else try pressing F8 at the startup if you can go yo the advance boot options.
go to repair my computer..select the language then select the username and password..then in system reco ery optios try startup repair or system restore.
else go to safe mode with networking...there in command prompt type sfc /scannow if you have vista or 7..else if you have the xp in advance boot menu try last know good configuration.
if the above step is not working try to use the windows repair with the oprating system cd.
insert the cd in to thr cd rom, restart the computer
press F12 at the startup it will give you the boot sequence then select the cd
and if none of the things are working contact Gateway..there might be a hardware issue
plese rate if you find this helpful..thanks
Aug 20, 2011 | Gateway Computers & Internet
How to add a new harddisk to a Gateway Peninum 3 550MHz machine and install win98?
Do you want to replaced the main HD or add a new one? If you want to replace the main one, buy a Hard drive under 160 gigs. I cant remember but 98 can not deal with a bigger one, you will have to cut it up or Partition it. Partition it down to 20 gig each. Do you have your Org. win 98 install disk? Get a setup program with the HD you buy. That program should let you Partition it and also format it to use with 98 or fat32. Once installed in the computer set the HD to master with switches located on the drive (small jumpers) As it boots up look for press DEL to enter setup. Get into the BIOS program and ck to see it it will locate your new hard drive you might have to set heads and scetors so make a note of the stamped on the drive. Once the BIOS has found the drive it is a matter of format w/ copy the command comm program from win98 you will have to have a good win 98 set up disk. Once you have formated the drive with fat32 and copied commamd.com you will need to install CD/Rom drivers you might have to find a good old win98 starup disk to boot up the cd. you might find a good old floppy with a cd intall on it at a local computer shop. if using an old win98 startup disk you can then put in the cd and at the Prompt type in cd win98 then type in  setup and that should be a good start.
Oct 23, 2009 | Gateway computers9: Pentium 3 Computer...
Instalation of windws 98
Change your bios setting to boot from cd. restart, choose start with cdrom support and follow the instruction
Mar 14, 2009 | Microsoft Windows 98 for PC
Dell inspiron 8100 notebook
You may need to try installing windows xp. I had a gateway that had a brand new hard drive and wouldn't take 98, but installed xp flawlessly. Look at the computer and see if it says designed for Windows XP
Jan 20, 2009 | Dell (0K724) for Inspiron 8100 40 GB Hard...
Networking, would like to live view security cam in another room
Since the webcam is connected to the win98 PC and the two computers are both connected to one router, then you can manage your win98 PC from your winXP by using a remote manage software. You may install to your win98 PC and winXP PC any remote manager software.
You may try VNC software. http://www.realvnc.com/products/free/4.1/index.html
Hope this helps!
Nov 14, 2008 | Belkin Computers & Internet
HELP
Are you trying to upgrade 95 to 98SE or just new install of 98.
What you may have to do is
  1. insert win 98 boot floppy
  2. boot with cdrom support
  3. at the prompt change to cd drive E:\ (press enter)
  4. at the E:\ prompt type cd Win98 (press enter)
  5. at the E:\Win98 prompt type format C:\ (press enter)
  6. confirm all data will be erased
  7. reboot with floppy in and at the a:\ prompt run FDISK to see if the full size of the hard drive is available. (option 4)
  8. If everything is normal exit fdisk reboot with floppy, choose with cdrom support, type in the cdrom drive letter (usually e) and cd Win98(change directory Win98)
  9. at the win98 prompt type setup (press enter) and follow the prompts.
May 30, 2008 | Compaq Armada 1500C Notebook
Pssword lock out
If you still can't find the solution try this thread: http://www.fixya.com/support/t156781-forgot_administrator_password
Oct 09, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
64 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
