Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
I need a hard disk drive for a cannon 2200 imagerunner the copier keeps showing a error message
    Brigadier General:
  • 10,406 Answers
If you have a Service Contract with the local CANON office, call them, and get them to make a service-call to fix your printer.
Posted on Jul 17, 2010
What does code E602-0003 mean on the Cannon Imagerunner 2200.
your copier hard disk has fried .change it and the copier will be ok
Aug 09, 2011 | Canon Office Equipment & Supplies
Have an error code of E602-0001. Please Help! The machine is a Canon imagerunner 2200.
This an error code for the failure of the Hard Disk Drive. You may be able to save the HDD by powering down the copier. While holding the 1 & 9 number keys at the same time power on the copier. This similar to a CHKDSK on a computer. Hold the two keys down until a rectangular box shows up on the display. If after lets say 20 seconds nothing appears then you will have to replace the HDD and reinstall system software. This may be better left to a qualified service tech. He will ahve to use special Canon software to complete this repair.
Jun 23, 2011 | Canon imageRUNNER 2200
Anytime i on my photocopier, this number shows on the screen-E602-0001 and cant do anything, what should i do?
hard disk has fried.replace it .Try to defragment it by keep pressing the 1&9 button and power on the machine.It will start the defragment mode.but eventually u have to change the hard drive
May 25, 2011 | Canon imageRUNNER 2200
CAnnon Imagerunner 2800 Error code: E000002 0000
SIR MY XEROX MACHINE IS PROBLEM ERROR CODE : E000002-0000
MACHINE MODEL : CANNON IMAGERUNNER 2200
Jan 18, 2011 | Canon (6981A002AA) for imagerunner 2200,...
Hoe i connect cannon digital copier 2200 with computer for use as printer
There are thrre things you need. First is a Network boot rom & a either net port & you need to flash the hard drive for printting
Sep 15, 2010 | Canon imageRUNNER 2200
Message d'error ir 2200
Hard drive is dead or dying. Will need to get tech to come out, replace hdd, format and load firmware using SST.
Here's something you can try to possibly keep the copier going till a technician can come. Turn copier off using main power switch (on right hand side of copier). Press 1 and 9 while turning it back on. Hopefully you see rectangles dropping on the screen. When this is finished should see download on the screen. Turn copier off then on again. If copier comes up with normal screen should work a little longer, but hard drive will die.
Jul 01, 2009 | Canon (6981A002AA) for imagerunner 2200,...
I have one cannon 3300 printer its showing error e602-0001 how can i rectify?
This is a hard drive error on the copier. You either need a tech to reformat your hard drive or you need a new one with new system software. They tend to go bad from time to time.
Mar 25, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
The cannon imagerunner 2200 shows the error code E000051-0000
Have you worked on the copier or has a service person just worked on the copier? The error code deals with the motor M3 not getting a signal to turn ON. Make sure you turn the copier Off and unplug it from the wall...... Then take the back cover OFF and look for connector J3040-2... The connector is most likely only part way in... Disconnect and reconnect it... Also, make sure all the other connection are all in correctly.... Good Luck.....
Mar 12, 2009 | Canon imageRUNNER 2200
Canon ir-2200 error E602-0002
E602 Hard disk failure.
Your hard drive probably has a problem, check connections, unplug everything from the board let sit for a few minutes then replug everything.
Sep 30, 2008 | Canon imageRUNNER 2200
Canon imagerunner 2200 error code E000602-0003
This is hard drive failure. If you another code other than 003 you may have gotten away with a scan disk, but not always. in your case the hard drive has died. a Canon Technician will need to replace it and re-install the machine's system software
Mar 13, 2008 | Canon imageRUNNER 2200
Computers & Internet Logo
160 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
