Question about GPS
I have a 2002 renault master van hazard lights & indicators have failed changed hazard light switch still does not work.When i lock van with remote indicator lights work in dash.
  • 11,800 Answers
I assume it also doesn't work on the Warning button and that you have checked the fuse and the relay. Since the indicator in the dash works then the only thing left is the wiring - most likely the wiring between the relay and the lights switch.
Posted on Jul 17, 2010
  • Vincenzo Tuzzeo Jul 17, 2010
    that is correct i have changed hazard light switch will now try to trace wiring to light switch,may thanks.
Audi a6 avant door
If all else fails you may need to change the central lock system control module. You need to supply dealer with Vin #
Apr 01, 2014 | 2003 Audi A6
High beam lights not work
seems like the multi-function switch is failing
easy to replace and fairly common
Dec 28, 2017 | Chevrolet Express Cars & Trucks
Hi wonderd if any one can help. i have a ford focus 2002 tddi estate the hazards arnt working but the indicaters are. i've changed the hazard switch for a new one and checked all the fuses in the
Look on the back of the fuse board ,for this you have to drop the fuse board as their are two fuses at the back and i know one is for the central locking ,the other ? Now when the hazard switch is disconnected the indicators shouldnt work but the only thing i can think of is the indicator unit is faulty ,do the hazards light the indicator lights up and they dont flash or is nothing happening?
Jan 24, 2013 | Ford Cars & Trucks
Cant find indicator relay on 03 clio
if you have trouble with your indicators or hazard lights change the hazard light switch get one on ebay.
Jun 19, 2012 | 2003 Renault Clio
Renault kangoo indicators and hazard lights have stopped working, checked the fuses there ok. Could you help?
Most common cause is a failed indicator relay. Just swap it with a known good one to confirm whether it's faulty but ensure it's correctly rated for your Kangoo.
After that, the next most common causes are more expensive: the indicator switch and the hazard light switch.
Nov 01, 2009 | 2000 Renault 181
Hi I have a 94 chevy g20 that the blinkers aren't flashing. Hazard lights are working fine. Walk around the van no lights are dead. Check all fuse everything is good. Any help would be great.
check the indicator flasher or relay that operate the blinkers or indicator light & hazard light system, check the combination switch for proper working if problem with it better replace it, if you are not able to solve the problem better take vehicle to nearest GM workshop for proper repair & checkup to be done & get the problem solve
Jul 22, 2009 | 1994 Chevrolet G20
I have a peugeot expert van 02 model 1.9 diesel fault is indicators stopped working and no hazard lights all lights flash when using central locking ive checked all fuses in interior and in engine...
check to see if you have power at the hazard light switch, it could just be unplugged, if u can get another good switch swap them over, i know its a power prob to that haz switch.
May 27, 2009 | 1987 Peugeot Liberte
Indicators do not work Although al lamps light when locking Car
Hazard warning light switch fault.
The hazard light warning button in the middle of your dash is actually a relay that often fails, causing this problem. New switch required.
Jan 12, 2009 | 2000 Audi TT
Renault Trafic 1,9 dci 2002
check other fuses and relays and re set fuel cut off switch
Jul 10, 2008 | 2002 Renault Sportwagon
GPS Logo
228 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
