Question about D-Link DP 300U (DP-300U) Print Server
I want to update the firmware on my d-link dp300u print server to version 2.2, how do I do it?
You can find HW firmware V 2.2 Rev B here
http://suporte.dlink.com.br/suporte/produto_detalhes.php?fa=DP&eq=300U
in the end of the page
Direct download link
http://suporte.dlink.com.br/suporte/arquivos/DP-300U/FIRMWARE/dp300u_v220_build_7(1027155911).zip
Posted on Jan 26, 2012
    Guru:
  • 632 Answers
Your type of d-link the highest version is 1.20 which can be downloaded from ftp://ftp.dlink.com/Printserver/dp300U/Firmware/dp300u_firmware_120.bin and updated on your d-link administrator page.
Posted on Jul 17, 2010
I need to reset the print server wireless D-Link Air Plus DP-G310 (dpg-310) Print Server but there are no reset button and reset jumper. In the manual book also doesn't stated anything about how to reset...
go here and click on the exact version of air plus you have
http://www.dlink.com/products/default.aspx?pid=DP-G310&tab=3
then click on firmware and download the latest version, flash the firmware to your print server and it will reset it to default
Mar 26, 2011 | D-Link Air Plus DP-G310 (dpg-310) Print...
I have print server dp300u it demand to password but i know this password plz tell how find password
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 21, 2011 | D-Link DP-300U (DHDP300U) Print Server
Canon IPF8000..... i need to override the "ink
Before removing the used print head, be sure to update the printer?s firmware version with the included CD-ROM. An error message will be displayed on the printer?s display when the new print head is installed without updating the version. In this case, re-install the used print head and update the firmware version.
Updating the firmware
1. Turn on the power of the printer. Check that the printer is online.
2. Run the file setup.exe in the FirmUpdate folder in the CD-ROM. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from Programs in the Start menu.
4. By following the instructions, update the firmware version.
2. Select the OS89 folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate]. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from [Applications] - [GARO Firmware Update Tool] folder.
2. Select the OSX folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate].
Precautions when updating the firmware version
- Use [GARO Firmware Update Tool] after checking that the printer is online.
- Do not turn off the power of the printer while firmware data is being transferred.
- If the printer?s firmware is already the most recent version, the Status of the target printer will be displayed as ?Update Finished? when using [GARO Firmware Update Tool].
Techbelkin
Dec 13, 2010 | Canon imagePROGRAF iPF8000 Printer
Is it compatible with windows 7?
The latest firmware for this print server only support Windows Vista and below , sorry to say that as of now it will not work with Windows 7. If Dlink releases a new firmware to make this unit with Windows 7 just need to update the firmware and you can use it for Windows 7 computers.
Sep 21, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Cannot connect to the firmware information server, please double check wan connection
You will have to update the firmware manually
Goto the website www.belkin.com/support
Click Routers
Under No 1 : Select N / G / B.... As given in the router
Under No 2 : Select the Model Number of the router
Under No 3 : Select the Version Number
Click next
Click on the link For firmware update ..... Download the appropriate version as your router
Save the file
on the address bar of internet explorer type http://192.168.2.1 and hit enter
On the left under utilities click firmware update
Leave the password blank and click submit
Click browse ,,, Locate the file you had downloaded and click update
Click OK For confirmation
Jul 28, 2010 | Belkin (F5D8231-4) Wireless Router...
Zebra Z4m+ won't print from Bartender 9.01
BarTender uses its own drivers for each model of printer you must install the correct driver, because there are differences in some commands a printer to another.
Mar 09, 2009 | Zebra Z4MPlus Printer
DP-G301
Update the firmware of your Print Server.
Mar 04, 2009 | D-Link AirPlus G DP-G301 (DPG301) Print...
D-Link DP-301P+ Print Server issue
- Kindly try to update the firmware of the Print Server.
Feb 24, 2009 | D-Link Express EtherNetwork DP-301P+ Print...
Configuration of DP300u in a LAN over Windows 2000
You just need to installe the . Inset the Printer Driver CD. It will Autoplay. Click on install the Driver.
After successfully installation of Driver, Go to Start-->Setting--> Printers and Faxes
You can find your printer here.Right Click on Printer --> Click on Sharing --> Give the Printer Name in Share Name.
You can installe the printer on client Machine by following way:
Go to Start-->Setting--> Printers and Faxes--> Click on Add Printer --> Check mark on Network Printer-->Clickn on Browse printer. It will Automatically discover your printer. Just Right click on it and clickon connect.
Sep 13, 2008 | D-Link DP 300U (DP-300U) Print Server
Router and New Print Server Not Talking?
what hardware version and firmware is on router.you might need to update firmware depending on what firmware is on now.
Aug 15, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
D-Link DP 300U (DP-300U) Print Server Logo
1,059 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
