Question about Canon PIXMA MP210 Photo All-In-One Printer
How to unjam paper when there is no paper jam
    Problem Solver:
  • 14 Answers
Usually its paper stuck inside, where you cant see
Posted on Jul 17, 2010
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
HOW DO I UNJAM SB 99C SHEDDER
Try spraying some WD40 into the cutting blades then turn it on to forward it may unjam itself.
Aug 25, 2014 | Fellowes SB-99Ci Shredder
Misfeed detected. Remove paper indicated by 0
misfeed is different then a jam. jam is the paper hit something miss feed the paper rollers can not pick up the paper. clean the rollers or replace them and or there associated clutches
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 21, 2014 | Konica Minolta Bizhub C451...
I have a new Canon MG 5250 printer, I loaded a full width but too short piece of paper to print, now says paper jammed but I cannot see any paper, how do I unjam paper
here is the procedure on how to remove paper jammed.
http://www.canon-europe.com/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MG_series/PIXMA_MG5250.aspx?faqtcmuri=tcm:13-776431&page=1&type=faq#Paper Is Jammed inside the Machine at the Transport Unit
Apr 27, 2011 | Canon Office Equipment & Supplies
Shredder jammed
For any jammed shredder..try the following.. pull backwards on the paper while you switch the machine into reverse. Try not to tear the paper as if there is nothing to hold onto then you can't help the motor.
If this dosn't work then you will have to take the top cover off(after unplugging of course.) and the try to force the paper backwards out of the machine by turnings the cutting blades or gears in the reverse direction.
Jun 04, 2010 | Royal 150MX Cross-Cut Shredder
HP Officejet 6310 All in One - small paper being faxed is jammed. How do I unjam the paper?
Lift the scanner lid, then lift the black part of the fax - pull up hard for it to lift. Unjam the paper either still on top or gently lift the inner section and retrieve your jammed paper. Then put everything back together and you're right to go again.
Oct 08, 2009 | HP Officejet 6310 All-In-One InkJet...
Jammed shredder
First UNPLUG THE MACHINE.
Unscrew four (4) screws, two in front underneath top cover and two in back of top cover. BE careful not to disconnect any wires.
Rotate motor gear or belt in reverse to remove jam. Do not put oil on paper because it expands the paper thickness and only makes it worse.
Sep 02, 2008 | Fellowes Powershred 480 Shredder
Paper Jam
locate at the back portion of your printer there is small rectangular like a door pull up and then get those paper that causes paper jam slowly see to it that there is no paper left....and start printing again if it does not worked then try to clean your paper rollers...
Oct 22, 2007 | HP Photosmart C6180 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
234 people viewed this question
old marine
old marine
