Question about Friedrich QuietMaster Deluxe RS12L10 Air Conditioner
Fan wobbles...why - Friedrich QuietMaster Deluxe RS12L10 Air Conditioner
  • 70 Answers
Bearing in the motor are going
Posted on Jul 18, 2010
I just installed a water pump on my 2003 gmc seirra and now the fan wobbles while running
You're going to need to disassemble everything according to the manual - following sequencing and order of operations carefully. Once you've reached the wobbly fan inspect the mounting and installation carefully. 1. Was it seated snugly and correctly into place. 2. Is it tightened adequately to prevent it from coming loose? (Remember: fan mounting bolts are generally reverse threaded to accomodate for fan spin, so righty loosy, lefty tighty this time!) 3. Are there any visible cracks or other damage to the fan, especially around the base or center core where it mounts.....4. finally, remove the fan assembly and inspect the bearing and mounting hardware carefully for damage. 5. Beyond these things, the only thing I can imagine is that you somehow bent/warped the fan housing, causing the fan to spin out of true (or wobbly!)
Apr 25, 2014 | JET Performance 2003 GMC Sierra 2500 HD...
Fan pulley wobble
If you can wobble the pulley by hand at any angle, it needs replacement. Check the other pulleys and the idler for wear as well.
Dec 17, 2013 | Chevrolet 2003 Chevrolet TrailBlazer EXT...
My fan is installed and it wobbles it is anchored properly from the box but the pole has a little play from the top not tightly secured The eletrician had to change the downrod was is on the fan at the...
Hi marilynh57....
Try removing the fan blades and putting them into different positions.
This will sometimes solve your wobbling problem as some fan blades are heavier than others and this causes the wobble you experiance.
Please take time to rate me
Aug 17, 2011 | Vacuums
I was trying to see if I could stop my fan from wobbling. After loosening the 2 phillips screws I twisted the upper housing slightly and the complete fan came loose(except for the wires). I just want to...
The fan wobbles cause you bought a crappy Harbor Breeze or Hampton Bay fan. The fan blades need to be balanced with a fan balance kit that comes in the box. You probably threw it out cause you didn't know what the package of weights was for. Get you a Hunter ceiling fan and you won't have an issue with fan wobble, because their fans have better quality control before leaving the factory. If you installed the fan without adequate bracket support- you best get a pro to help you out cause there is no fan wobble help for stupidity.
Jun 05, 2011 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
Wobbly ceiling fan
Make sure the blades are not loose.
Jun 11, 2017 | Hampton Bay HL52QV-P-3LC14 Brass Landmark...
New fan with downrod wobbles when on high speed and low speed. Does not wobble on medium speed. How do I stop the wobble completely?
Measure from the same spot on the ceiling to the outer most tip of each blade (by rotating to the tape). The distance should be the same, if not check fan blade screws for tightness. You might have to bend the fan blade brackets a little to get the same measurements, if the screws are all tight. If all this lokks good, you might to use a balancing kit...just follow the instructions...it's not too bad to do
Feb 18, 2010 | Hampton Bay Dryers
Ceiling fan wobbles How do i balance it ??
you go to the hardware store and buy a ceiling fan balancing kit
Jun 18, 2009 | Honeywell HT-800 Table Fan
Hampton Bay Ceiling fan wobbling
The fan came with one or more clips and some small weights that easily stick to the blade. Now with the clip you put it in one of the blades, starting from the far end and coming inwards, little by little. Try putting the clip in the middle of the fan and turn on the fan and see if it continues wobbling, if it continues wobbling try moving it to left and right and every time turn on the fan and see what happens. When you find the correct spot, there you glue the small weight.
Apr 09, 2009 | Universal Remote Control Hampton Bay...
Wobbly Fan----Nutone Whispaire WA6500
Definetly need a new blade
#K7458-000 Boan/nutone part number
Dec 09, 2008 | Broan-NuTone Intermediate Whispaire ...
Friedrich QuietMaster Deluxe RS12L10 Air Conditioner Logo
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Dennis Boxerman
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
