Question about General Electric SPEAKER SYSTEM FOR IPOD SPKR
I would like to connect my ge speaker system for ipod 98909 to another stereo or tv so we can listen to my ipod. Is that possible it didnt come with a manual
    Sergeant:
  • 298 Answers
There is an alternate sound jack. try connecting it to the other device
Posted on Jul 17, 2010
What do you think the problem is as to why my ipod want load up,i keep getting the message ipod communication aborted.
bad receiver in the radio, or, the transmitter on the ipod is bad. try it on another bluetooth source to see if it maintains connection, if not, the ipod could be damaged or bad. If it works with another bluetooth source unit, then the radio has a bluetooth receiver issue.
We sell low priced replacements!
http://advancedelectronic.net/
Nov 22, 2014 | Pyle PLDN74BTI Car Video Player
Tip
How do i connect my iPod to a Pioneer Car Stereo
<p>It is advisable to listen to your iPod through headphones while driving in the car. Not only is it dangerous to completely cancel the sounds of the road as it is often illegal in many cities across the country. There is an alternative, however. In just a few steps you can use your iPod to your car stereo speakers and use the car to listen to your music, podcasts and audiobooks. No brand car stereo makes it easier to connect these beautiful than Pioneer. <br /> <p><br /> <p>1. Connect one end of the mini-jack on your iPod headphone jack. Once done, set your iPod or on your dashboard or your car seat so that it will not tip over while driving. <br /> <p><br /> <p>2. Find your sound system's auxiliary input Pioneer. It is often located in front of the front panel stereo, but can also open the front or back of the unit completely. If the extra connector on the back of the stereo itself, then you remove the panel. When it comes to this, see the instructions that came with your sound system is provided for further guidance. <br /> <p><br /> <p>3. Connect the other end of the cable mini-jack for stereo aux port. This will allow your iPod to the audio signal through the cable to the stereo and the stereo signal will pass to the car speakers. Most often, when something is plugged into the stereo aux jack will work in stereo. In some models a setting to select the additional connection. Whatever the case, now you can sit and enjoy your iPod for that long car ride. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How do I connect my iPod to a stereo Kenwood
<p>The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod. <br /> <p><br /> <p>1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see. <br /> <p><br /> <p>2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack. <br /> <p><br /> <p>3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected. <br /> <p><br /> <p>4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off <br />
Connect an active soundbar to a receiver
What if the soundbar is Bluetooth? Will I still be able to use that function and connect the active soundbar to the tv (Bluetooth) and connect the av receiver for other surround sound speakers? (they are pre-wired in the walls in the apartment I moved into)
Jan 08, 2013 | Audio Players & Recorders
How do i connect an ipod to my sony str-de310 receiver
Connecting to a home stereo
  1. For most home stereo systems, connect iPod to your amplifier's sound input using a 3.5 mm mini stereo to RCA adapter cable.
  2. Adjust the volume on iPod to less than half to prevent overdriving your amplifier. Adjust the listening volume using your stereo's controls.
    Note: Depending on your stereo, iPod may need to be set higher than half in order to get a proper volume through external speakers.
http://support.apple.com/kb/ht2167
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 12, 2011 | Sony STR-DE310
Tip
How to connect my iPod to an Amp & Subwoofers
<p>If your iPod to your amplifier or subwoofer that connects to a stereo receiver. This can be done through an additional cable. <br /> <p><br /> <p>1. Locate the auxiliary input on your stereo connected to your amplifier and subwoofer. These entry, small and round is labeled "AUX". Usually this entry is available in front of the stereo, but some devices can be found on the back. <br /> <p><br /> <p>2. Connect another cable to the auxiliary input of your stereo. <br /> <p><br /> <p>3. Connect the other end of extra cable to the headphones of his iPod. <br /> <p><br /> <p>4. Press the "AUX" input button on your stereo. Now when you play a song on your iPod you listen to them on your speaker system including subwoofer and amplifier. <br />
Wireless speakers?
There are many available on the market the type you should buy depends directly upon the type of connections that you have on the audio output.
Most wireless speakers have a sender unit that connects into the 3.5 mm stereo jack plug socket of your audio source, but you can get a stereo splitter to L R audio if that is what you have, this will still work. Also look for ones that have 2 channels or more so that you can choose the best of all the possible signal frequencies.
The other question is how big is your house the range of most is only 10 meters where still get a quality signal they will work over an longer range but your quality will suffer.
Oct 07, 2009 | B&W Bowers and Wilkins Zeppelin iPod Music...
Just what do you do . put into cirgaret lighter and the other into ipod shuffle is there something on the radio to turn on
if you are listening through the headphones provided with the ipod then no. if you plan to listen to the ipod through car speakers, some factory car stereos come with an input jack that somewhere on the front panel of the stereo that you connect the ipod to. please rate me if this helps. thanks and good luck!
Sep 18, 2009 | Apple iPod shuffle MP3 Player
Would like to listen to tv through the 5.1 speakers and don't know how to hook them up to do so, please help
You can run red and white from tv out to in on reciever, or optical out tfrom tv to in on reciever or digital coax audio from tv out to in on reciever, depending on which connections you have. then you would put your reciever on aux to hear tv through surround system. Also if you have a cable box or satellite box you can run the audio from that box to the input on surround system.
Hope this helps.
May 05, 2009 | JVC TH-G30 Theater System
General Electric SPEAKER SYSTEM FOR IPOD SPKR Logo
134 people viewed this question
Top General Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a General Audio Player and Recorder Expert? Answer questions, earn points and help others
