Question about Marshall MG100HDFX 100-Watt Amplifier Head
The loop and the manual tone store functionality !
I am lil' bit confused about the loop function and the manual tone store functionality. please tell me what is loop in here and how to use it? and how can i store my own tone in it ? please tell me the procedures... i'm a new amp user :(
  • Marshall Master
  • 5,603 Answers
Usually the loop in is used with an EXTERNAL effects module where the audio signal is "looped" out through the external effect module and then back to the power amp to drive the speaker in the cabinet. The LOOP IN jack would receive signal from the EFFECTS module OUT jack.
The source to go TO the effects module INPUT may come from a jack such as preamp out, or sometimes the same loop jack if it usess the TRS (Tip-Ring-Sleeve) connection method.
If you do not have an external effects module, all this is a moot point in your case.
Posted on Jul 17, 2010
Casio WK-3500 How to save keyboards/tones
Yes there's a way. Use Registration Memory (I shorten it to: RM) ..
RM have 8 banks and 4 bank numbers. For changing banks, press BANK several times.
Example :
  • choose tone (eg:500)
  • press BANK where you want to store. (eg:1)
  • while holding down STORE button,press registration number where you want to store (eg:3) Release store button. Finish.
Next :
  • choose tone (eg:038)
  • while holding down STORE button,press registration number where you want to store (eg:4) Release store button. Finish.
Anytime you press RM bank 1 number 3 (one key), the sound is 500
Anytime you press RM bank 1 number 4 (one key), the sound is 038.
Notes:
  • RM not only can save tone, but can store style,overall setting live performance,etc.
  • RM functions are disabled while you are using the SMF player, song memory or demo.
  • RM are also disabled while you are using the floppy disk drive.
Jul 10, 2015 | Music
How can i do the reset factory for a piano Casio Privia PX-120?? It have the tone/settings button but not the function button. anyone know?
You don't need to reset factory.
You just need to change the setting of LOCAL CONTROL.
Lets start :::
While holding TONE / SETTING button,press key D#7 at 7th octave (highest octave on the right hand). Then release. That's all.
Then the sound must be heard..
Mar 12, 2015 | Casio PX120 Privia KEy ESSENTIALS BUNDLE
How to program the zoom 3030 pedal back to factory setting
From the Owner's Manual:
1. disconnect the AC Adapter to the 3030 (Make sure amp volume is all the way down)
2. While holding the STORE key down, reinsert the AC adapter to power back on. (..AL.. will flash on the display, indicating that the 3030 is standing by for the 'All Initialize' operation.
3. Press the STORE key again. The All Initialize function will be executed, and the Play mode returned. To cancel All Initialize function, press EDIT key. This cancels reset, returns to Play mode.
Sep 05, 2014 | Music
Can i add more memory to the rc50 loop pedal
You can make a backup on your pc and load back Default settings or restore to default settings. Normally you should have I quote ' with up to 49 minutes of mono recording time (or 24 minutes in stereo), the RC-50 can function as a song recorder as well as a looper'
I have the RC300 which has 3 hrs recording time. But when i reach the limit. I make a backup and load back in a initial default setup which I have downloaded somewhere. But you can also restore to default from the unit itself. Hope this helps
Apr 14, 2017 | Boss Rc 50
Buttons are not working
Long Back I had the same problem I just reloaded the OS and every problem went off try this
Mar 26, 2012 | Music
When I arm a track to record in tracktion 3 I get a delay when monitoring playback.
If you monitor the recording there are two delays... one as audio is converted and stored... the next is when it is retrieved and converted back to audio. Usually the recording interfaces have a monitor function that loops the audio back out before the conversion. playing back previously recorded audio of course will have the delay to retrieve and convert back to audio.
Jul 03, 2011 | Mackie Onyx Blackjack 2x2 Recording...
The control for the Effects Loop Mix seems to function like a master volume control. I get no sound in ay channel if the Effects Loop Mix control is in the "EFF" position (right) and sound...
That is the way it is supposed to work... It is a level control to control the level sent to an EXTERNAL effects unit. What external effects unit are you using? Brand and model please. If you proportion more to the effects loop, you want to make sure the EXTERNAL effects unit is on and its gain controls are up. The foot switch input should control the EXTERNAL effects unit when you plug the footswitch into the EXTERNAL unit. The footswitch input on the amp itself has NOTHING to do with the external effect loop, it only affects the amp's own DFX unit.
Jun 25, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
How do i make my mpk49 pads work with samples, in other words, when i press the pad once the loop will play or the sample will play all the way threw, but right now when i press the pad, it only plays how...
Have a look in your manual at the sections on Note Repeat and Time Division.NOTE REPEAT] – Holding this button while
striking a pad causes the pad to retrigger at a
rate based on the current Tempo and Time
Division settings. The Note Repeat feature can
be synced to an internal or external MIDI Clock
source. [NOTE REPEAT] can function as a
latching or momentary button
19. [TIME DIVISION] – This button is used to specify
the rate of the Note Repeat and Arpeggiator
features. When [TIME DIVISION] is activated,
you can press one of the 8 switches to specify a
time division. [TIME DIVISION] can function as a
momentary or toggle button.
Please note that while [TIME DIVISION] is active,
the 8 assignable buttons will not function as MIDI
CC or Program Change switches until [TIME
DIVISION] has been de-activated.
20. [ARP ON/OFF] – This button enables and The manuals and updates can be downloaded here:http://www.akaipro.com/mpk49 Please let me know if this helps.
Nov 30, 2009 | Akai Music
Analog acoustic modeling
About the cable,
This is from peavey.com:
. Plus, the Generation guitars that feature ACM come with a dual-ended cable that sends the two tones to two different amplifiers, opening up even more tone possibilities.
Sep 12, 2008 | Peavey Music
Marshall MG100HDFX 100-Watt Amplifier Head Logo
260 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
