Question about Refrigerators
Fridge not cold enough but motor seems to be on
    Sergeant:
  • 298 Answers
Adjust the thermostat knob. it is usually inside the fridge
Posted on Jul 17, 2010
Why is the fridge and freezer not cold enough
If the fan isn't running neither section will be cold enough. There may be something jammed against the fan blade or the motor could be defective.
Jul 19, 2014 | Smeg FAB32RNN 50s Retro Style Black 304 l...
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
I have a Matsui MUL1107WW fridge and the motor appears to be cutting out when the fridge gets too cold. Is this normal ? or does the motor need looking at ?
The compressor motor only needs to run to cool the fridge down.
Once the fridge is cold enough the compressor motor will switch off.
The compressor will start again when the fridge warms up
May 02, 2011 | Refrigerators
Both fridge and freezer aren't getting cold enough in my Maytag Fridge
if they are both cold, but not cold enough, one of two likely scenarios, one minor, one major. the major one, you haev a sealed system leak of refrigerant, several hundred dollars to repair.
the minor, your condenser fan motor is not running, its job is to cool the compressor, if its not cooling the compressor, when the compressor gets too hot, it will shut itself down, while the fridge continues to run. when this happens, the unit seems fine first thing in the morning, but by evening it seems less fine...while everyone sleeping, doors have been closed, allowing unit to "catch up". replace fan motor.
Feb 27, 2010 | Refrigerators
Fridge motor on too much it seems
Remember, the colder you make the thermostat, the longer the compressor will run to try and reach the required temperature. Question is," is the temperature in the fridge cold enough or not cold enough." If it is, then you will need to have the thermostat replaced.(there is no control). If not cold enough at any time, then there is an issue with the cooling circuit.(Will then need to have it checked by a technician.
Nov 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Fix it fridge
the compressor does not properly run ,motor valve weak ,test w/ amphere meter if does not match w/label amphere , comp. motor problem.
Dec 31, 2007 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
