Question about HP Pavilion dv6000z Notebook
Lcd darkened windex screen.
I was cleaning my laptop screen with windex and it seeped into my screen and now most of my screen is darkened except for a random bright streak at the bottom of my screen.
what do i do? should i send it back to the manufacturer?
Hello
try the following:
try first of all to clean the screen using a wet towel because the problem might be that the windex has made a dark layer on the screen ...
if this does not work then if u have a vacum machine that can can get the screen dry by blowing air on it...this might work
if not then you have to send it back to the manufacure
good luck
Posted on Apr 21, 2008
Windex between screens
If the cloud like image is black then you have damaged your screen by applying too much pressure on the screen.
You should use special LCD screen spray and soft cloth to clean your screen to gently clean the surface of the screen.
Replacement :CD screen maybe available for your laptop from this WEB site.
LCD screens and Inverterswww.lcdparts.net
Apr 14, 2012 | Compaq Presario CQ62-219WM Notebook
Tip
LCD or computer screen dirty?
The best way to clean it up is with a microfiber cloth VERY lightly moist with warm water. No soap. No solvents. No alcohol of any type. NO WINDEX. NO 409 or any household cleaner. Be sure that if you're cleaning an LCD screen that you apply VERY little pressure, otherwise you can damage the screen.
For an old-fashion CRT screen (NOT A FLAT SCREEN LCD), you can use the same as above or you can use a small amount of water + rubbing alcohol. Be sure that the liquid doesn't drip INSIDE the monitor.
on Mar 26, 2010 | Computers & Internet
I have three black circles, and some color streaking at he bottom inch of my RCA, LCD tv
that is usually caused by cleaning the screen with windex the windex runs down the screen bewteen the screen and plastic frame and actually seeps inside between the screen layers. Eventually it may go away by itself if the circles are not too bad but in most cases the damage is permanent.It can also be an issue called screen delamination which there is no fix for.
Mar 02, 2012 | RCA Televison & Video
I was windexing the screen when i noticed the it was seeping in behind the screen. now i have windex behind the screen in two large clumps and it looks bad. i tried a blowdryer, all the did was heatup the...
Do not ever use anything other than warm water and a soft rag to clean your LCD screen!!!!!
Possibly use a little mild dish soap on a damp rag, but make sure the rag is only damp.
You have now ruined your screen and most likely will need to replace it.
Apr 23, 2011 | Toshiba Satellite A215-S7422 Notebook
How to clean screen
Use a fine rag and water ONLY. Windex will ruin it.
Jun 30, 2010 | LG 42LC2D 42 in. LCD HDTV
I spilled a small amount of beer on my gateway m-1625 laptop and now everything seems to be working except the screen so i am trying to take it apart. i have taken most of the screws out but it still wont...
If your have the time, Hose down the pc with windex, through the leyboard, and any other openings that are available. Set the unit aside for at least three days in a warm area. This will dissolve any beer residue and allow the windex to totally evaporate. Try to run the unit after you are fully sure that all of the windex has evoparated.
You should be good to go unless you have burned out the video processor. If the screen still doesn't work, you can attach an external monitor to test it. If it works, you haven't burned up the processor, but you most likely have ruined the screen circuity.
If that is the case, then good luck. Go online and goole Gateway Notebook Repair. You'll have quite a few choices to select from.
Rich
Rich
Dec 15, 2009 | Gateway M-1625 Notebook
Powers up. Nothing on the screen except dim light.
Take the computer into a darkened room.
Can you read the screen? Does the text/icon on the screen look "normal"?
If so, then the "back-light" on your LCD has failed.
It's about $20 to replace the part, and about $60 for the technician's time to replace the part.
Nov 14, 2009 | HP Pavilion dv9700t Notebook PC
2 yr old spayed approx 60ml of windex over the
The windex may have seeped up into the screen. It should dry in a few weeks.
Oct 03, 2009 | Joy Toshiba M105 S3002 Notebook
I need to know how to clean the LG flatron L1953T screen without damaging it in any way? should we just used windex or not? it has been wiped with a damp cloth and now has water marks.
Please do not use Windex. Use Anti-Static Monitor Wipes for LCD screens. Using Windex or other cleaning solutions like it will cause streaks on your screen. Damp cloths have the same effect as Windex.
May 04, 2008 | Computers & Internet
Screen darkening from right side
1 lool
change lcd panel ok
Jan 19, 2008 | Lenovo ThinkPad R51
HP Pavilion dv6000z Notebook Logo
409 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
